I've been trying to find out if there's any way to display a continuously updated elapsed time in the final output video using Vegas Movie Studio HD Platinum 11.0.
I'd like to be able to display the movie's total length as static text 'mm:ss', and it's current position in the timeline as a continuously updated 'mm:ss'.
Any bright ideas?
Thanks!
Started out with valve radio, crystal microphone & reel2reel tape recorder with 'magic eye' level indication...
Not sure if the studio version has this, but in the pro version you apply the Timecode FX
Thanks for the quick reply.
I've just taken a look and it appears it does. Haven't tried it yet, but looks good.
Well done, and thank you!Started out with valve radio, crystal microphone & reel2reel tape recorder with 'magic eye' level indication...
Vegas Movie Studio HD Platinum 10
By jjblackisback in forum SubtitleReplies: 3Last Post: 26th Apr 2011, 20:28 -
Movie Studio HD PLatinum adequate after Vegas 7 ?
By Prieur in forum EditingReplies: 3Last Post: 25th Feb 2011, 10:38 -
why do some dvds not allow elapsed time/chapter to display?
By spiritgumm in forum Newbie / General discussionsReplies: 0Last Post: 9th Feb 2011, 10:27 -
Vegas Movie Studio Platinum 10.
By EagleW in forum EditingReplies: 0Last Post: 15th Jul 2010, 20:03 -
What is the difference between Vegas Pro and Vegas movie studio platinum
By jbitakis in forum Newbie / General discussionsReplies: 4Last Post: 18th Feb 2009, 00:41
