  1. Member kaaviyan's Avatar
    Hi all,
    Is there any way in x264 where i can Cut A Video without losing quality using megui or any other equivalent software......
    i mean specific scenes or parts of a vid.....
    Moving you to our editing section.
    Yes, you can edit x264 without reconverting. I don't use megui so I don't know if it includes andy simple cutter.
    Or else can you try avidemux. I don't know if it supports raw x264 streams though.
    And you can only cut at keyframes without reconverting.
  3. Member sanlyn's Avatar
    Originally Posted by kaaviyan View Post
    Hi all,
    TMPGenc Smart Renderer.
    Our inventions are wont to be pretty toys, which distract our attention from serious things. They are but improved means to an unimproved end. -- Henry David Thoreau
    You can also try VideoReDo TV Suite H264. There is a free trial that is fully functional.
  5. MKVMergeGUI can be found in the "MeGUI/tools/mkvmerge" folder. It's called mmg.exe. The splitting options are under the global tab. As Baldrick pointed out though, you need a "smart cutter" which can re-encode the video around the cut point in order to cut on exact frames. MKVMergeGUI will cut at the first keyframe it finds after your specified cut point(s). At least I think that's what it does.
