Hi.
I have a few 240fps videos that I want to slow down to 24fps. Virtualdub doesn't open these mp4 files. I've tried Avidemux but it only goes up to 200fps, and I can't seem to slow it down, maybe it's just me doing it the wrong way.
I also have Freemake Video Converter but I haven't found a way to slow it down there.
Do you think Avidemux can do it? Or should I try something else?
Thank you in advance!
Results 1 to 12 of 12
Thread: Slow down a video 10 times
Try remuxing and marking the video track as 24 fps. That way there will be no loss of quality. The audio will be out of sync though.
where did these videos come from ?
i had/still-have an LG phone that will record at 120 Fps
but the files automatically play back at 30fps, its for high speed capture -slow mode play
never had to 'reduce speed' on them, even when i moved them to the PC -
You can use mymp4boxgui to demux and remux and set the fps as jagabo suggested. It works for gopro hero3 240fps videos for pc playback, but I don't know if it will work ok for your phone or other devices. It's worth a shot since it's a lot faster than re-encoding, and no quality loss
btw. does someone know a place where to download non-edited 240fps material of the gopro hero3? (I googled a bit but stumbled only over reencoded material)
Thanks from here too. I keep a collection of odds-and-ends videos so I downloaded the 240 fps video. Remuxing with the frame rate marked as 24 fps slowed the video down as expected. Remuxing to MKV worked as well.
Movavi Convert Video/DVD - experiencing very slow conversion times
By motoyaya in forum Portable VideoReplies: 2Last Post: 18th Dec 2012, 05:20 -
SONY VEGAS PRO 11 and new pc, very slow render times with Neatvideo
By christodoulidesd in forum Video ConversionReplies: 11Last Post: 3rd May 2012, 16:40 -
Video becomes distorted at times.
By Nagashi in forum Software PlayingReplies: 3Last Post: 22nd Aug 2010, 20:24 -
DVD to H.264 - Different Running Times, Chapter Times Wrong
By nrogers64 in forum Newbie / General discussionsReplies: 0Last Post: 17th Mar 2009, 18:28 -
Samsung HT-BD2R slow disk load times
By swheller in forum DVD & Blu-ray PlayersReplies: 2Last Post: 24th Feb 2009, 11:26
