Closed Thread
  1. Member kaaviyan's Avatar
    hi all,
    Recently i tried encoding a video, in MeGui, but it stopped half way through and when i checked the log it showed me this......
    My MediaInfo about the original video
    General
    Complete name : G:\Movies\Venghai (2011) - Tamil Movie - Ayngaran - DVDRip - 720p - Esub\Venghai (2011) - Tamil Movie - Ayngaran - DVDRip - 720p - Esub.mkv
    Format : Matroska
    File size : 4.40 GiB
    Duration : 2h 35mn
    Overall bit rate : 4 052 Kbps
    Encoded date : UTC 2011-09-27 16:19:30
    Writing application : mkvmerge v4.9.1 ('Ich will') built on Jul 11 2011 23:53:15
    Writing library : libebml v1.2.1 + libmatroska v1.1.1
    Video
    Format : AVC
    Format profile : High@L3.1
    Format settings, CABAC : Yes
    Format settings, ReFrames : 5 frames
    Muxing mode : Container profile=Unknown@3.1
    Codec ID : V_MPEG4/ISO/AVC
    Duration : 2h 35mn
    Nominal bit rate : 3 800 Kbps
    Width : 1 280 pixels
    Height : 540 pixels
    Display aspect ratio : 2.35
    Frame rate : 23.976 fps
    Resolution : 24 bits
    Colorimetry : 4:2:0
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.229
    Writing library : x264 core 116 r2074 2641b9e
    Encoding settings : cabac=1 / ref=5 / deblock=1:-1:-1 / analyse=0x3:0x133 / me=umh / subme=6 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=3800 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
    Audio #1
    Format : AAC
    Format version : Version 4
    Format profile : LC
    Format settings, SBR : Yes
    Format settings, PS : No
    Codec ID : A_AAC
    Duration : 2h 35mn
    Channel(s) : 6 channels
    Channel positions : Front: L C R, Rear: L R, LFE
    Sampling rate : 48.0 KHz
    Resolution : 16 bits
    Audio #2
    Format : AAC
    Format profile : LC
    Codec ID : A_AAC
    Duration : 2h 35mn
    Can Anyone plz. tell me what the problem is and the solution to it please.....
    Many Thanks.....
  2. Lone soldier
    If file is MKV, in MEGUI select Tools, File Indexer and run it.
    Select your file, checked all audio and run.
    After this encode your video.
    Claudio
  3. Member kaaviyan's Avatar
    Claudio
    no buddy...i still get the same error....
  4. Lone soldier
    On MEGUI select Tools, HD stream extract and run it.
    Select your file, checked all audio stream and change to WAVS
    Try and reply.
    Claudio
  5. I don't use the One Click encoder, but try using MKVCleaver to extract the audio from the original MKV and add it to MeGUI's audio section, then add a separate audio encoding job to the job queue.
    If the video is being converted okay you can add the encoded audio to the encoded video yourself using the appropriate muxer under the tools menu..... assuming the audio re-encodes that way.
  6. Member kaaviyan's Avatar
    Try and reply.
    Claudio
    i tried both ur methods and i get an error like this in both the methods....
    Now i get an error like this...
  7. I'm a MEGA Super Moderator Baldrick's Avatar
    This is not any blu-ray ripping/conversion. Buy your movies instead of downloading warez crap material.
