So, I have 2 videos:
test.avi (bad quality, 1 english audio track)
test2.mpg (good quality, 2 german audio tracks)Format : AVI
File size : 76.2 MiB
Duration : 8mn 0s
Overall bit rate : 1 331 Kbps
Video
Format : MPEG-4 Visual
Format profile : Simple@L3
Format settings, BVOP : No
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 8mn 0s
Source duration : 8mn 0s
Bit rate : 1 189 Kbps
Width : 512 pixels
Height : 384 pixels
Display aspect ratio : 4:3
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.202
Stream size : 68.1 MiB (89%)
Writing library : XviD 1.1.2 (UTC 2006-11-01)
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Mode : Joint stereo
Mode extension : MS Stereo
Codec ID : 55
Codec ID/Hint : MP3
Duration : 8mn 0s
Bit rate mode : Constant
Bit rate : 128 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Stream size : 7.33 MiB (10%)
Alignment : Split accross interleaves
Interleave, duration : 24 ms (0.72 video frame)
Interleave, preload duration : 185 ms
Now, what I want to do:Format : MPEG-PS
File size : 153 MiB
Duration : 7mn 41s
Overall bit rate : 2 791 Kbps
Video
Format : MPEG Video
Format version : Version 2
Format profile : Main@Main
Format settings, BVOP : Yes
Format settings, Matrix : Custom
Format settings, GOP : M=3, N=12
Duration : 7mn 41s
Bit rate mode : Variable
Bit rate : 2 352 Kbps
Maximum bit rate : 15.0 Mbps
Width : 480 pixels
Height : 576 pixels
Frame rate : 25.000 fps
Color space : YUV
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.340
Stream size : 129 MiB (84%)
Audio #1
Format : MPEG Audio
Format profile : Layer 2
Duration : 7mn 41s
Bit rate : 192 Kbps
Delay relative to video : -430ms
Stream size : 10.6 MiB (7%)
Audio #2
Format : MPEG Audio
Duration : 7mn 41s
Bit rate : 192 Kbps
Delay relative to video : -424ms
1. Remove the audio tracks from the mpg video;
2. Remove the audio track and extract it to a losskess audio file from the avi video;
3. Add the extracted audio track to the mpg video;
4. Sync the video with the new audio track.
NOTE: the both videos (avi and mpg) have the same scene action, the only difference is the quality and the audio (english versus german).
How can I do this or is possible?
Thanks!
You've got over 15 seconds of time difference between the two clips.
You need to visually check to see if you can remove that time difference from the larger file, either at the beginning or end of the longer video. You can't just "mux" the short audio to the long video and expect it to look right/sync up.
One's from an NTSC source, the other is PAL. It's almost an exact match-up in length if you extract the AVI's audio and change it to PAL speed. In something like BeSweet, you'd use the 23.96->25FPS preset. In something else you'd want it something like 95.904% of its original length.
How to combine *.264 video + *.aac audio to one file?
By video-fan in forum Video ConversionReplies: 5Last Post: 18th Oct 2011, 02:38 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 07:54 -
How to combine video data and audio data in realtime
By mudassar in forum Video StreamingReplies: 0Last Post: 31st Aug 2010, 08:00 -
How do i combine a video file and audio for two different movie sources??
By Kyisha in forum Newbie / General discussionsReplies: 3Last Post: 22nd Mar 2010, 06:03 -
How to combine video with audio file and replace audio with video files ?
By designbuyers in forum Newbie / General discussionsReplies: 2Last Post: 8th Feb 2009, 11:12
