  1. Member kaaviyan's Avatar
    does anyone know how to encode a movie without any audio....
    i tried selecting 'none' in the audio box in 'one click encoder mode' but still the audio is there in the output....so are there any other ways to do it....
    Many Thanks.....
    Moving you to our conversion section.
    I don't use megui but I guess you can edit the avisynth script to not include audio.
    Or remove the audio after you converted with a mp4 or mkv multiplexer like mymp4boxgui or mkvtoolnix.
  3. yes, I just check it, it creates audio track even if you set never, and you cannot remove that track,
    advantage of Megui is that it can load Avisynth script,
    if you cannot create one or it is inconvenient, you can use Avisynth script creator, then choose file index , it will create avs script, not sure if it creates two scripts for video and audio separately, you can load that script into Megui and choose Queue for video, NOT Auto Encode at the bottom of screen . Or you just erase that audio input part manualy. If it creates only avs script for video and audio separately you will load just video avs script.
