Hi
i need to create a dvd authored for the australian market. i already have it for the uk market am i'm aware that pal in australia is slighly different from the uk version.
will my pal version made for uk work in australia is my question then?
Results 1 to 9 of 9
Thread: australian dvd
philippe
Australian PAL dvd's work fine for for UK. I can not see why the opposite should not be true.
The difference is the Region Code but I suspect your dvd will be Region-free anyway. -
There isn't any special pal-dvd format for australia. So yes it will work.
In fact, as Baldrick states, I just remembered that a few years back I was sending PAL dvds all over the world - including 'Down Under'. And, yes, they played just fine.
heck54 - it wasn't you was it who told him?
From Wikipedia:
PAL-B/G/D/K/I
The majority of countries using PAL have television standards with 625 lines and 50 fields per second, differences concern the audio carrier frequency and channel bandwidths. Standards B/G are used in most of Western Europe, Australia and New Zealand, standard I in the UK, Ireland, Hong Kong, South Africa and Macau, standards D/K in most of Central and Eastern Europe and Standard D in mainland China. Most analogue CCTV cameras are Standard D.
Systems B and G are similar. System B is used for 7 MHz-wide channels on VHF, while System G is used for 8 MHz-wide channels on UHF (Australia uses System B on UHF). Similarly, Systems D and K are similar except for the bands they use: System D is only used on VHF, while System K is only used on UHF. Although System I is used on both bands, it has only been used on UHF in the United Kingdom due to the black-and-white 405-line "System A" TV services on VHF operating until the 1980s. -
Yes, there are multiple flavors of both NTSC & PAL, and even SECAM in the broadcast world and this makes for fragmented & complicated receivers.
But we're not talking about BROADCASTING, we're talking about simple wired baseband connections (with DVD/BD, HTPC, or media player sources), and in that context there are only 2 kinds of SD systems: NTSC-based, and PAL-based (which includes SECAM material). That makes everyone's life easier.
Australian PS3 wont play PAL DVD's in North America
By hsd in forum Newbie / General discussionsReplies: 3Last Post: 16th Jan 2012, 18:04 -
Need codes to convert Australian DVD player into a multi region DVD player
By Seajacb123 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 13th Oct 2010, 01:00 -
Can an Australian bought DVD recorder pick up UK digital frequencies?
By crossylad in forum DVB / HDTVReplies: 5Last Post: 27th Oct 2009, 02:51
