  1. Member pchan's Avatar
    Hi All,
    I have a video clip with AC3 audio. I select Direct Stream Copy for audio. But the output audio is PCM and not AC3.
    I am using version 1.9.1.1. What have I not done right ?
    Thanks in advance.
    Did you use an import plugin for vdub? If so which one?
    Some import plugins will decompress the file (uncompressed) so if use direct stream copy it will be uncompressed output . eg. directshow import plugin will do this .
  3. Member pchan's Avatar
    I use DirectShowSource to load MTS video clip into VirtualDub. Is there other ways around it ?
    avisynth frameserves uncompressed audio & video
    workaround is tsmuxer to demux audio from MTS , in vdub , audio=> audio from other file, select demuxed audio (and audio => direct stream copy)
