I have downloaded a concert in bluray ISO format and want to rip some performances into M2TS by using DVDfab but since the AACS protection is there, I have to remove it first. I tried to use Passkey to remove the protection but somehow it didn't work for me. I mounted the concert to a virtual drive (drive E) using Daemon tools and when I opened Passkey, it didn't automatically bypass the protection for me. I clicked on the info tab and it says that the disc isn't opened. I've attached an image to my post showing exactly how it looks like when I opened passkey. Can someone take a look at it and give me some advice on how to fix this?
Thread: Removing encryption problem
Have you tried dvdfab decrypter or makemkv?
Or rerip from your original blu-ray. -
dvd encryption
By devdev in forum Authoring (DVD)Replies: 6Last Post: 3rd Dec 2012, 16:31 -
Removing Noise.. NeatVideo VirtualDub problem
By David Animator in forum EditingReplies: 2Last Post: 1st Apr 2012, 16:43 -
Is WPA encryption really better than WEP?
By yoda313 in forum ComputerReplies: 34Last Post: 25th Oct 2009, 22:14 -
Best encryption algorithm?
By alegator in forum ComputerReplies: 5Last Post: 10th May 2009, 23:37 -
BD+ encryption blue-ray
By herbapou in forum Blu-ray RippingReplies: 4Last Post: 24th Mar 2009, 07:58
