Hi,
When I leave the audio track selection on Default, it sometimes picks some other random track and not the one it is saying is the default. When I manually select the track (even if it says it is the same one as the default) it does use the right one. What gives?
The tracks may not be labeled correctly for the software to recognize them on some videos.
Also where the video comes from can make a difference. In the US, I sometimes get foreign videos that default to the country of origin language track, even though all the menus, disc and sleeve info is in English. But someone else here may have better information.
And welcome to our forums.
Hi,
The problem is not the track that it chooses as the Default, the problem is that it doesn't actually USE the track it says it has chosen. In fact, if you are breaking up chapters into separate files, it even sometimes uses different audio tracks for each chapter!
For example, a title may have three tracks:
[80] English 'AC3' 6 chs
[81] English 'AC3' 2 chs
[82] Deutsch 'AC3' 6 chs
Supposing it has chosen the default as:
DEF: [80] English 'AC3' 6 chs
If you leave this selection, it sometimes uses other tracks instead. I can send you a copy of a disk that it does it with, if you promise it can be fixed?
Setting default audio track with TsmuxeR
By bruce73 in forum Newbie / General discussionsReplies: 5Last Post: 30th Jul 2012, 07:24 -
VOB2MPG Pro: wrong default audio for separate titles
By aurgathor in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 31st May 2012, 10:09 -
Strange audio shift when using other audio track than default
By Heliooos in forum DVD RippingReplies: 2Last Post: 25th Mar 2010, 00:46 -
selecting audio track
By july in forum AudioReplies: 0Last Post: 9th Jan 2009, 15:13 -
How can I change default audio track with DVD Flick?
By jimdagys in forum Video ConversionReplies: 3Last Post: 8th Feb 2008, 06:16
