    I've been using VSDC editor for a while now to make videos. but for some reason now whenever I build my project (or rather try to) no items show up and it wont let me convert anything!
    can anybody give me advice on how to fix this?
    Buy a real editor? It looks like it is abandoned.
    i'd rather not if I don't have to, the editor itself is perfect for everything i need to do.
    and this doesn't happen all the time, i have been able to make it build it once or twice but I don't know how I keep doing it
    If you have been using it for a while, then double sheck that you are using the current version 1.2.2. There were some bugs in the previous version, particularly when trying to save your final file it would sometimes hang up. Just open the program, click on Help, then click on "Check for Updates".
  5. I was having the same problem. I tried changing the Build window from maximized to not maximized, so it doesn't fill the whole screen, and that seemed to fix it.
