Hello,
I am attempting to convert an MPEG-2 video asset to WMV VC-1 for use on xbox360. I am trying to convert the MPEG-2 audio to the "Windows Media Professional 10" audio codec with 6 channels. The main encoder I am using Rhozet Carbon Coder however; before encoding even starts I get very generic encoding error which basically informs me that Rhozet could not find the source of the problem. Encoding does work if I target 2 channels. To get more information I tried converting using FFMPEG but the error I get from that is: to many channels: got 6, need 2 or fewer.. Here is the MediaInfo analysis of the file:
Obviously something is wrong with my source audio format but I have 6 channels so I do not see why encoding would fail? How would I go about converting this MPEG-2 source to WMV VC-1 using "Windows Media Professional 10" with 6 channels? Do I need to convert it to another format first or is my source using the wrong audio format?General
Complete name : C:\Test\Test_Asset.mpg
Format : MPEG-TS
File size : 1.36 GiB
Duration : 6mn 29s
Overall bit rate mode : Constant
Overall bit rate : 30.0 Mbps
Video
Menu ID : 1 (0x1)
Format : MPEG Video
Format version : Version 2
Format profile : Main@High
Format settings, BVOP : Yes
Format settings, Matrix : Default
Format settings, GOP : Variable
Codec ID : 2
Duration : 6mn 28s
Bit rate : 28.0 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 2.107
Frame rate : 29.970 fps
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.451
Stream size : 1.28 GiB (94%)
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio
Menu ID : 1 (0x1)
Format : AAC
Format version : Version 4
Format profile : LC
Muxing mode : ADTS
Codec ID : 15
Duration : 6mn 28s
Bit rate mode : Variable
Bit rate : 309 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Stream size : 14.3 MiB (1%)
Text
ID : 481 (0x1E1)-6
Menu ID : 1 (0x1)
Format : EIA-708
Muxing mode : A/53 / DTVCC Transport
Muxing mode, more info : Muxed in Video #1
Duration : 6mn 28s
Bit rate mode : Constant
Stream size : 0.00 Byte (0%)
Would appreciate any help.
Thread: MPEG-2 to WMV VC1
ffmpeg cannot encode wmapro (so it's limited to stereo wma), that's why you're getting that error message
some programs might have problems with the .mpg extension for a transport stream (their splitter might not expect 5.1 AAC), so you might try renaming it to .ts, or .mts
you can try expression encoder , or avisynth + wmnicenc (this should work for sure, but requires avisynth knowledge) -
Spending the rest of your life converting videos so a stupid Xbox or PS3 will play them is no way to live when you could just buy a Western Digital streaming media player ONCE and be good to go for years to come. Your choice. I bought mine something like 4 years ago and it still works and I still use it. It's one of the very best purchases I ever made and it has far exceeded its cost in terms of the enjoyment it's given me and not having to convert everything to Divx/Xvid just so a DVD player could play various videos.
We have very few people here who encode with VC-1 for the Xbox for exactly the reason I described above, but perhaps one of them will provide some guidance.
I am no expert, but MPEG-2 even at HD resolutions may be OK for the Xbox, but that audio is almost certainly going to have to be converted. I hate AAC audio and don't use it so others with experience will have to comment. Perhaps you need only convert the audio to make the Xbox play it, but still, the Western Digital players would play that file as is.
Is it possible to take VC1 & convert DTS-HD to WMA Pro 5.1 and mux to WMV?
By bobthegoat2001 in forum Authoring (Blu-ray)Replies: 5Last Post: 16th Dec 2011, 10:12 -
MPEG Streamclip / Converted WMV to MPEG-4 but only got the audio? Help me.
By aka_director in forum Video ConversionReplies: 0Last Post: 3rd Oct 2010, 22:24 -
m2ts VC1 to WMV
By -Sandro- in forum Video ConversionReplies: 2Last Post: 22nd Aug 2010, 14:59 -
VC1 + (Patched) DTS + WMV on PS3?
By ecsjr in forum Newbie / General discussionsReplies: 3Last Post: 27th Feb 2010, 09:02 -
CLI to WMV/VC1? (WMV3)
By RogerTango in forum Video ConversionReplies: 11Last Post: 9th Nov 2009, 22:02
