  1. Hello,
    I was working on a DVD slideshow GUI project (.dsg file), then I exported the file as .mp4.
    And lately, I wanted to edit the project.
    Unfortunately, I got this error message : "Can not load the file D:\...dsg" at the end of the loading.
    I did not change anything between the export and the recent opening...
    Is there any log ? or any clue I can follow to find the problem ?
    Thanks in advance.
  2. Did you open the .dsg file as a project? (and not as a slide?)
  3. Actually, I opened the .dsg file by double-clicking.
    Then, I tried to open it through the GUI, as a project, and I get this error :
    Can't perform inequality test on nothing against number menupaste() in file "C:\Program Files (x86)\DVD slideshow GUI\DVDslideshowGUI.exe", line 2246:
    > if (kb_bank[int(ani[i]), 0, 0]) > -1 then
  4. Are you using the included or newer version of Avisynth?
    If you open the dsg file in notepad, what does the last lines look like?
  5. The last lines are :
    4
    -100
    25
    1
    It finishes with en empty line (I mean that there is a \r\n after the "1").
  6. Hello,
    I've got some news.
    In the .dsg file, there is a number after the path of each image. It seems that this number increases after each "saving" of the project. And it seems that, after a certain amount of incrementations, this number reach a limit, and the .dsg file can't be loaded.
    In my case, when this number starts from 766 and goes to 907 (I got 142 slides actually), the program crashes.
    Tell me if I can provide my .dsg file for help.
    I edit manually (with Notepad++) the .dsg in order to bypass the bug.
    Hope I can help !
    Cheers
