HD Fury 3 & Sony RDR HX 900 Hd Dvd Recorder Questions
Before I begin i do have a fair av background but i am not an expert
in the av world so please be kind if my questions sound stupid .
Has anyone tried HD Fury 3 using a stand alone Dvd Recorder ?
I own a ( Sony HRD HX 9000 Stand Alone Dvd Recorder .
This is one of those Rare Stand Alone Hard Drive Dvd Recorders with
Component ( In Puts )
I used the following Set-Up With HDFury 3 )
( HDFury 3 With VGA To RCA Component breakout Adapter Cable )
LG BluRay Player HDMI output to HDFury 3 HDMI input
HDFury 3 RCA Component output to Stand Alone Dvd Recorder Component input
Dvd Recorder Component output to LCD Tv Set .
Outcome :
Blank gray screen on Sony RDR HX 900 Recorder.
I finally figured out that I am getting a blank gray screen on my Sony Recorder because my Bluray Player
does not have a 480i Over HDMI ability , so the hd fury 3 with component breakout cable is not coming in to
my Sony Recorder as SD 480i .Was HD Fury 3 made to only work with Tv Monitors and will not work with component input Stand Alone Dvd Recorders .
Or will a bluray player thats 480i over hdmi capable .work with my hd fury 3 to Sony RDR HX 900 Recorder.?
Or would i need a hdmi converter to change my hdmi bluray player signal to 480i over hmii ?
I do understand that I would only be getting SD 480i recording quality and thats ok ,
But will It Work ? Can Anyone Help...
Best Regards , blc7772001
Yes, if your blu-ray player has the composite output, use that instead of hdmi.
That is likely the best choice for hardware.
Yet I suppose the fury is used for cp bypass.
I don't know if you can send a signal via hdmi that your dvdrecorder will understand.
Someone else might know for sure.....
You cannot record high def. with your dvd player anyway......
Best way is the rip the blu-ray to hard drive then use something like BD Rebuilder to
convert blu-ray to dvd.
You could rip blu-ray to hard drive...burn back to blank blu-ray...then playback in blu-ray player
and use composite output to dvd recorder and get a fairly good recording...the quality will depend on your
recorder setting. This is however going around the world to go next door..... -
blc7772001, the quick answer is your setup will work as long as you get a player that sends 480i via HDMI. There are some out there, just have to look. I use my HDFury's (2 or 3) between an Oppo 980 upscaling player with the hdmi output set at 480i and either the Sony 900 or 715. The key, as you suspected, is to have a player that can be set to output at 480i and you're good to go. Don't forget the audio cable, 3.5 mm to stereo (red and white). It really does a great job.
Have fun.
CC -
Thankyou CrazyCanuck ,
Your the best , I was really worried that I made a big costly mistake with buying Hd Fury 3 , But you put my mind at ease.
I did find a OPPO DV970 at amazon with this description ( Pure and clean 480i NTSC / 576i PAL over HDMI )
Should be delivered at my door soon .
Two more questions if you don"t mind ,
hd fury 3 dip switches : I have not changed any switches but did look over the manual but don't fully understand the optional dip switching yet. Should i just leave the dip switches as they are or is there something you can recommend for best picture settings and picture formats .
Also I am looking for a mid range price for a Blu Ray Player that has 480i over hdmi that offers streaming for both youtube and vudu , I found a few but they only offer either youtube no vudu or vudu no youtube .
Do you have a recommendation .
Thanks for your time , best regards blc7772001 -
Glad to be of help blc7772001, I've never touched the EDID switches, from what I understand, the HDFury switches are originally set at default by the builders. They don't do much for your (our) intended purpose, they're more for issues with various non-HDCP displays, no benefit for this purpose. As for the format it's WYSIWYG, nothing with the switches. I set my OPPO to send 480i at 16:9 (wide, not auto) to do anamorphic dvds and 4:3 letterbox for letterbox dvds.
No recommendation for the BR player and I believe that we (in Canada) don't get vudu anyway so not much help from me on that.
One thing I've notice and haven't quite figured out a good go-around is when I connect everything up and turn on the Oppo and the Sony 715 (or 900) the image is flickering (and the HDfury blue light) and the only way I've found (so far) is to unplug and replug the Oppo HDMI output, then I'm ready to record.
You will most likely encounter this issue. I suspect a handshake issue, now that's something that maybe, hopefully can be resolved by an EDID switch which is more one of their intended purposes. I'm not too bothered by this, like I said, unplug and plug back in the player's HDMI output.
Bluray player steaming with hd fury 3 to sony rdr hx 900 recorder
By blc7772001 in forum CapturingReplies: 1Last Post: 20th Jan 2013, 20:05 -
Problem with Sony RDR-GXD500 DVD Recorder
By FearMor in forum DVD & Blu-ray RecordersReplies: 2Last Post: 22nd Dec 2012, 05:17 -
By FearMor in forum Newbie / General discussionsReplies: 0Last Post: 25th Nov 2012, 13:41 -
Sony RDR VX420 Combi Recorder
By Megamaniac in forum Newbie / General discussionsReplies: 2Last Post: 15th Nov 2009, 09:19 -
WOOT! Sony RDR-GX255 DVD Recorder for $55
By lordsmurf in forum DVD & Blu-ray RecordersReplies: 3Last Post: 6th Sep 2009, 20:06
