Hello guys! I am trying to convert an .MKV file to .MP4 to play in a PS3. The problem is it doesn't matter the settings I put in "Video Encoding" the encoded files passes the video in fast motion and the audio goes normal. I want to convert to hardsub the subtitles to the video. The subtitles appear, but the video since the beginning goes to fast, like if I were fast forwarding it.
Can anyone help me? Thank you!
Closed Thread
Thread: Xvid4PSP synchronization problem
General
Unique ID : 199279216314248020893780543531859497440 (0x95EBC7EF9302FBE04AB35C3DC08AD1E0)
Complete name : C:\Users\Klaus\Desktop\Django Unchained 2012 DVDSCR X264 AAC-P2P\du.mkv
Format : Matroska
Format version : Version 2
File size : 2.48 GiB
Duration : 2h 45mn
Overall bit rate : 2 148 Kbps
Writing application : HandBrake 0.9.8
Writing library : libmkv 0.6.5
Video
Format : AVC
Format profile : Main@L3.0
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : V_MPEG4/ISO/AVC
Nominal bit rate : 2 000 Kbps
Width : 720 pixels
Height : 354 pixels
Display aspect ratio : 2.40:1
Original display aspect ratio : 2.40:1
Frame rate mode : Variable
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Writing library : x264 core 120
Encoding settings : cabac=1 / ref=1 / deblock=1:0:0 / analyse=0x1:0x111 / me=hex / subme=2 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=0 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=1 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=10 / rc=abr / mbtree=1 / bitrate=2000 / ratetol=1.0 / qcomp=0.60 / qpmin=3 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Language : English
Default : Yes
Forced : No
Color primaries : BT.601 NTSC
Transfer characteristics : BT.709
Matrix coefficients : BT.601
Audio
Format : AAC
Format profile : LC
Codec ID : A_AAC
Duration : 2h 45mn
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Compression mode : Lossy
Language : English
Default : Yes
Forced : No
Menu
00:00:00.000 : Chapter 1
00:10:15.114 : Chapter 2
00:20:42.908 : Chapter 3
00:30:03.051 : Chapter 4
00:40:30.344 : Chapter 5
00:51:04.277 : Chapter 6
01:01:36.409 : Chapter 7
01:10:02.248 : Chapter 8
01:19:23.225 : Chapter 9
01:31:48.920 : Chapter 10
01:40:14.224 : Chapter 11
01:50:27.170 : Chapter 12
02:00:50.376 : Chapter 13
02:10:20.479 : Chapter 14
02:21:04.088 : Chapter 15
02:30:36.110 : Chapter 16
02:37:27.020 : Chapter 17
Audio video synchronization problem?
By antonymaheshca in forum Newbie / General discussionsReplies: 1Last Post: 14th May 2011, 05:26 -
DVD synchronization, without synchronization device and normal dvd players
By 10shyam in forum Newbie / General discussionsReplies: 4Last Post: 9th Mar 2011, 17:52 -
Synchronization problem converting S-video to computer
By mtolesen in forum Video ConversionReplies: 4Last Post: 28th Apr 2010, 08:05 -
Audio synchronization problem when re-encodingwith StaxRip...?
By Stb1990 in forum Newbie / General discussionsReplies: 2Last Post: 15th Apr 2010, 22:42 -
Video/Audio synchronization problem with XviD4PSP
By pyromanic in forum Newbie / General discussionsReplies: 0Last Post: 30th Jan 2008, 19:40
