Version 1.5.34023 seems to be the last one where this key command (SHIFT+Backspace) works for me (e.g. it jumps the to the middle of the file as expected). In all newer versions this key command jumps to the end of the file (seems to be happening both in 32bit and 64bit versions) although menu command (right click -> Playback -> Jump (to) -> Middle) works fine.
Am I the only one experiencing this?
Results 1 to 12 of 12
I don't know how many others are experiencing it, but I've used potplayer in windows (definitely not my favorite BTW) and I've seen features dropped on "updates". Personally I think they're just one of those concerns that makes endless unnecessary updates to try to get more revenue.
If it really bugs you that much why don't you just uninstall it and install the older one? Since they make many needless updates, what would you lose? -
Yes it really "bugs" me and I did stay with 1.5.34023 because of that, although not all the newer updates are "needless".
The point of my post here was to find out whether I am the only one experiencing this, and if not then how this could be fixed / properly reported. -
You mean that pressing Shift+Backspace on your keyboard does jump the playback to the middle of the file being played?
I just installed latest 1.5.35431 and the problem still persists. I redefined keyboard shortcuts for jumping to middle / end as Ctrl+Up / Down in Preferences and this way I can use my keyboard for jumping - tt's just those predefined default shortcuts are not working (for me). -
No I did not (then none of the keyboard shortcuts would work at all)Originally Posted by mzso
No way. How could I "mess up" anything if simple reinstallation of 1.5.34023 brings the functionality back? Then if I install any newer version over it -> it does not work. Then if I install 1.5.34023 over that newer version again, it works again (I do not perform any other steps than simply proceeding the installation process)Originally Posted by mzso -
I don't think they did intentionally - otherwise they would report about it (they did report introduction of these shortcuts for version 1.5.32392 as seen here http://www.dvbsupport.net/info/potplayer.htmlOriginally Posted by mzso
Also, if you use your mouse (right click) and go Playback > Jump (to) menu you can see the keyboard shortcuts are still assigned AND if you choose to jump this way (e.g. via mouse) PotPlayer jumps just fine.
Arrgh.. "Easy Video Splitter" doesn't seem to work with Windows 7
By Wakewatcher in forum EditingReplies: 10Last Post: 14th Jan 2011, 22:19 -
How to add subtitles link to "update ifos" doesn't work
By sinuhemoises in forum Newbie / General discussionsReplies: 1Last Post: 3rd Apr 2010, 14:35 -
VDub "add to job control" option...not there anymore?
By CursedLemon in forum EditingReplies: 2Last Post: 17th Nov 2009, 09:47 -
I cant get anymore "watch in high quality" link on youtube after
By foler in forum Video ConversionReplies: 1Last Post: 17th Feb 2009, 09:34 -
API "SetParent" in VB6: Function & Ctrl keys don't work
By gll99 in forum ProgrammingReplies: 4Last Post: 9th Mar 2008, 19:37
