Hello,
I have this video plays well on HD, but freezes after burning to DVD disk. I copied it from DVD to HD and it plays well again. Why? Here is some info on the video.
HTML Code:General Complete name : C:\Video.avi Format : AVI Format/Info : Audio Video Interleave Format profile : OpenDML File size : 4.37 GiB Duration : 1h 10mn Overall bit rate : 8 812 Kbps Movie name : Video Director : N/A Writing application : Lavf54.3.100 Video ID : 0 Format : MPEG-4 Visual Format profile : Simple@L1 Format settings, BVOP : No Format settings, QPel : No Format settings, GMC : No warppoints Format settings, Matrix : Default (H.263) Codec ID : XVID Codec ID/Hint : XviD Duration : 1h 10mn Bit rate : 8 673 Kbps Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 1.600 Frame rate : 25.000 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Compression mode : Lossy Bits/(Pixel*Frame) : 0.167 Stream size : 4.30 GiB (98%) Writing library : Lavc54.15.100 Audio ID : 1 Format : MPEG Audio Format version : Version 1 Format profile : Layer 3 Mode : Joint stereo Mode extension : MS Stereo Codec ID : 55 Codec ID/Hint : MP3 Duration : 1h 10mn Bit rate mode : Constant Bit rate : 128 Kbps Channel(s) : 2 channels Sampling rate : 48.0 KHz Compression mode : Lossy Stream size : 64.9 MiB (1%) Alignment : Aligned on interleaves Interleave, duration : 24 ms (0.60 video frame) Interleave, preload duration : 72 ms
Results 1 to 9 of 9
I guess it freezes on your computer? And not any standalone player?
Maybe crappy dvdr media so your dvd reader can't read it fast enough for playback.Last edited by Baldrick; 19th Jan 2013 at 08:54.
More details if you want help.
Did you burn this as a data disc?
What are you playing it on when it freezes? PC? Standalone (need details if it is this)?
Most standalones will not support playing Divx/Xvid with resolutions above 720x576. -
Your file is HD (High Definition), but your nomenclature is confusing. When you say "HD" do you mean High Definition, or Hard Disk (HDD = Hard Disk Drive)?
If this HD file plays from your HDD, but won't from a DVD disk, then there's a good chance you're using bad blank DVD disks. -
it is always half that cater to full here in this forum.
Sorry about the incorrect use of acronyms. By HD I meant hard drive.
Correct, the video file plays well on hard drive, but won't play on DVD disk. After I copied the file from the DVD disk back to the hard drive, it played well again.
When I was burning the DVD as data disk, I was also doing other tasks. Could that affect the outcome? -
Unfortunately Nero has some default settings that are not very helpful.
Download and install the free ImgBurn program. Use it to burn another disc. You will have to use UDF format. Use version 2.01 and nothing higher.
Having said that, one possible problem is that Nero burned you a UDF 2.50 or higher format disc and your PC doesn't understand that version of UDF. If you are using Windows XP or earlier, try installing the free UDFReader program and see if that magically fixes your playback problem. However, you should still look into ImgBurn as it's more reliable than Nero. -
AVI file on Verbatim DVD-R plays fine on laptop but freezes on TV!
By Benji2012 in forum Newbie / General discussionsReplies: 3Last Post: 27th Jun 2012, 16:34 -
computr freezes/crashes when burning dvds
By agent222 in forum Newbie / General discussionsReplies: 18Last Post: 9th Aug 2009, 15:07 -
Home DVD Freezes Up in multiple areas of video
By shopforchrist in forum Authoring (DVD)Replies: 1Last Post: 17th Mar 2009, 20:29 -
Gui dvdauthor disc plays on pc but freezes on normal dvdplayer?
By extent in forum Authoring (DVD)Replies: 13Last Post: 9th Feb 2009, 12:50 -
Help with burning a .vob file to DVD so it plays on a dvd player
By Volume in forum Newbie / General discussionsReplies: 1Last Post: 1st Nov 2008, 11:41
