Hello All!
I recently had to replace my computer and I am now running W8; of course I have everything Retro-ed to look like and work as much as possible as earlier versions. I'm trying to run MKVExtract which I HAVE placed in the MKVTools directory in my Program files as instructed. The program opens just fine, but when I go to input the MKV file (just a standard movie file muxed with an MPEG4 Video stream and a DTS Audio stream and a Vorbis Commentary track, which is the reason why I am doing this because my OPPO player does not recognize Vorbis files and I simply want to extract the commentary and convert it to MP3 which it DOES recognize) BUT... as it loads the file I get this error:
Access violation at address 004F2BEC in module 'MKVExtractGUI2.exe' Read of address 0000000D
And, NO streams appear to extract in the lower pane like they are supposed to do.
WHY is this? Does this program not run with W8? I've 'Taken Ownership' of both the MKV file and the install files, so I'm wondering what I can do? This SHOULD be so bloody simple, but it is turning into this HUGE ordeal.
If I simply CANNOT use this program, there MUST be some other easy way to extract the Vorbis commentary file and then convert it to MP3, right...?
Any suggestions would be LOVELY!
Thanks!
_____________L@the
Thanks kindly Baldrick! I had seen that one mentioned before and I will add that to my arsenal.
Actually, I somehow stumbled on this page where this girl explained how you could use VLC Player not only to extract the audio track I wanted, but also to convert it to MP3. It was SUPER simple and worked great! I never realized you could do that with VLC
Cheers!
winavi 8.0 access violation error address 0000000 ??????
By confundido in forum Video ConversionReplies: 5Last Post: 24th Jun 2010, 21:14 -
An out-of-bounds memory access (access violation)
By rjc7394 in forum Video ConversionReplies: 0Last Post: 17th Jun 2010, 17:42 -
Virtualdub....An out-of-bounds memory access (access violation) occurred...
By zzyzx2 in forum Video ConversionReplies: 0Last Post: 8th May 2010, 00:40 -
VirtualDubMod Access Violation Crash
By k3yword. in forum EditingReplies: 1Last Post: 29th Jul 2008, 19:19 -
Virtualdub - out-of-bounds memory access (access violation) Lameacm
By kidcash in forum Video ConversionReplies: 1Last Post: 21st Jan 2008, 08:34
