  1. Hello everybody.
    We have three Canon XHA1 which we want to use for recording.
    I don't know exactly why someone chose these cameras but now i have to fix it.
    the cameras are built into a room so i dont work with tapes.
    the cameras are connected via firewire and i can capture e.g. using flash live encoder
    when cameras are set to SD (DV). I would like to do that for HDV, too.
    Problem is that Live Encoder wont capture HDV from that camera.
    the only tool working properly, every time i want to capture a test situation
    is HDVSplit. The only Problem is the big file size.
    Is there a way to capture the HDV from Firewire and encode it on the fly to a smaller file, for example FLV ?
    that would be awsome.
    Each camera is connected to an own PC (Win/Ubuntu)
  2. Member themaster1's Avatar
    Have you tried VLC video capture options ? You should have if not
  3. i did. somehow its not possible to do that.
    it would be wonderful. maybe i just have not found a way.
    i found a way using ubuntu:
    dvgrab -format mpeg2 -buffer 300 - | ffmpeg -deinterlace -f mpegts -i - -f flv -vcodec flv -s 1920x1080 -aspect 16:9 -qscale 3.5 -acodec libmp3lame -ab 32k -ar 22050 timestamp.flv
    this gibes me an flv with errors some times. i have to try that on a good pc.
    until now thats the only way to get fullHD live recording directly to an flv for me.
    i hope there is something more comfortable.
    edit: just tried vlc again: streaming working on win7 64bit
    but until now no encoding
