  1. Hello!
    I have an MKV file that has chapter information.
    How to extract the video in a particular chapter without re-encoding the file?
    I would try solveigm avi trimmer. You have to select start and stop manually though. But no reconverting.
  3. Originally Posted by Baldrick View Post
    Thank you for the reply. But I am thinking there might be a way so we don't need to manually set the start-stop points. Instead take advantage of the chapter information in the MKV file.
    Is this possible?
    I haven't seen any such software. Maybe you could write something for the mkvmerge command line...but it would be too complex...
  5. Thank you for your reply.
    I muxed the MKV file into TS files and used H264TS Cutter for cutting the files. And yes, I stil have to manually enter start-end points.
    I have to mention that 'solveigm avi trimmer' did show an option to cut out MKV chapters. But the option in not working. Something to do with a software bug I guess.
    Sorry for such late reply, but it took me time to figure out.
    Last edited by blazzer12; 29th Jan 2013 at 17:18. Reason: omitted an important detail. start-end points.
