When I import video from a DVD, Sony Movie Studio creates a series of 5-minute mpg clips. I add the clips to the timeline to edit. When I play the clips on the timeline, however, there is a noticeable gap between clips.
Are these gaps only noticeable on the timeline? Will they disappear once burned to a DVD?
I would like to know if there is a way to import one large mpg clip instead of numerous 5-min clips. If not, is it possible to join clips and remove the gaps between them? Thanks.
Is this a homemade DVD from a DVD recorder.....where someone set the recorder to insert chapter markers every 5 minutes?
santiam,
if you have (Sony Vegas) Movie Studio 12 (or 11), google 'gary james + import dvd'. -
That method worked perfectly. Thanks for the tip.
I didn't make the DVD, so there was nothing I could do about the chapter markers. However, it looks like it will take Movie Studio over an hour to render a DVD that is 1:44:00 in length.
The video is already DVD compatible mpeg2, so I'm surprised it takes so long. Is it normal to take this long?
Importing avi (divx) Files in Sony DVD Architect/Sony Vegas
By mltwitz in forum Video ConversionReplies: 12Last Post: 6th Jan 2011, 06:56 -
Problem with importing audio from movie track - Sony Vegas Pro
By tooninoz in forum Newbie / General discussionsReplies: 0Last Post: 18th Nov 2010, 00:39 -
Importing an MPEG-4 to sony vegas platinum 9
By txpredator in forum Newbie / General discussionsReplies: 0Last Post: 24th Oct 2010, 19:25 -
Problem with Sony Vegas importing DVDs
By aporreca in forum EditingReplies: 2Last Post: 31st May 2010, 09:28 -
Importing from SONY HDR-SR1 to SONY VEGAS 8 MPEG Video resolution
By UltimateEnd in forum Camcorders (DV/HDV/AVCHD)Replies: 0Last Post: 19th Oct 2009, 11:00
