Hi Guys,
Having just focused on solving one problem ( audio noise ) , i end up with another.
I have started using smplayer to watch movies , using the in-built card on my pcb. having watched movies on my smaller 20 inch lcd 720p with no problems.
I connected my hdmi to the 32 inch 1080p full hd and the same movies ( any movie ) produces a kinda ghost streak effect . You can see it better in moving scenes .
I have down scaled from 1080p to sxga where the effect is much less obvious .
My top whack resolution is 1280 x 1024 , which is what the sxga gives me.
However, the picture quality is nowhere near as good as the 1080p .
my pc goes up to 1080i / 720p.
Any suggestions , see if smplayer - the tv or buy a better hdmi cable will do.
BTW : My setup - from my pc to a vga to hdmi converter to my tv. the converter is the Startechpro, with osd menus. tried them all .
Thanks.
Those don`t work through wine some how, some things do but those don`t - i`m on linux.
VLC came with kubuntu in 2008 . I installed the windows portable version last week ( runs ok through wine - closes when i go to a file from playing and try and start another from the list ) , other than that it`s great.
Bad news is - even with codecs ready packed can`t get it to play h264 - 720p and 1080p fail badly !
The best media player for me is smplayer now that I fixed how to play files in the order i put them in.Last edited by Atotaloss; 17th Jan 2013 at 13:16.
1080p YouTube video falls apart in full screen
By brassplyer in forum Newbie / General discussionsReplies: 16Last Post: 12th Sep 2012, 20:12 -
SMPlayer not remembering to start maximized (different that full screen)
By natalia25 in forum Newbie / General discussionsReplies: 2Last Post: 27th Jun 2012, 09:26 -
Full 1080p videos on pc (Processor or video card?)
By neworldman in forum ComputerReplies: 4Last Post: 24th Jan 2011, 19:04 -
Tricky out put for Full HD 1080P in After Effects
By Chikyujin in forum DVB / HDTVReplies: 5Last Post: 6th Apr 2009, 11:37 -
Full HD vs True HD vs HDReady 1080p?
By therock003 in forum DVB / HDTVReplies: 15Last Post: 2nd Jan 2009, 19:21
