Hi guys,
I found a video, and i'd like to create a similar 3D effect, but i don't know how.
Can you help me?
https://www.youtube.com/watch?v=YalvVxeWO_I
Thread: How can I do this effect?
Those are just scaled images using the background wall as a frame template. Measure the postiion of the tile corners and use them to scale the images then superimpose them over the tiles.
Brian. -
Depends heavily on the software that you have at your disposal as well. I use After Effects and if I were to do this effect here is how I would approach it:
1. Film or otherwise get footage of the tiled wall used in the background. Footage also looks color-graded, so I'd apply a color grade.
2. Prepare the clips that "come out of the wall". Note that they include color clips as well as video clips, and the video clips are scaled down (or the color clips are scaled up) such that the color clip below serves as a border.
3. Finally, use motion tracking to set each clip sequence to follow select tiles as the video progresses.
Brainiac
Help with speciale effect
By Enz088 in forum EditingReplies: 5Last Post: 8th Sep 2011, 00:05 -
CRT-TV Effect
By Ancalagon in forum EditingReplies: 3Last Post: 23rd Jun 2011, 13:06 -
Anyone know how to do this effect?
By bojadada in forum EditingReplies: 1Last Post: 17th Feb 2010, 00:31 -
what effect is this?
By daiweb in forum EditingReplies: 1Last Post: 7th Nov 2009, 16:19 -
What causes this Ghost Effect?
By NBninja8 in forum Camcorders (DV/HDV/AVCHD)Replies: 4Last Post: 27th Jan 2008, 14:41
