Hello!
The web-video became a "puzzle" for a short time after switch from fullscreen to normal video window.
The video: http://dvb-t.atw.hu/video.html
Thank you for your reply!
Results 1 to 18 of 18
Okey. It looks fine in chrome(builtin adobe flash player) but like this in firefox(adobes external player):
MTS file (Canon LEGRIA HF G25, 24Mbit/s max settings) were transcoded into 8Mbit/s x.264 FLV video with Xmedia recode. The very best quality settings in x.264 encoder. -
I would try put it in a mp4 and see if it works better. Yes, mp4 works fine i flash.
Or you might have too complex h264 levels/settings for adobes flash player.
Or it might be something wrong with xmedia recode, some versions are very buggy. -
Here is the mp4 version: http://dvb-t.atw.hu/mp4.html
It couldn't help
Better but a pixel party.
What are your h264/x264 settings?? -
HERE ARE MY X.264 options:
Here is the original MTS camcorder file: http://dictaphone.atw.hu/mozdony.MTS (it's only 67Mbyte)Last edited by Stears555; 16th Jan 2013 at 12:19.
works fine here with chrome and firefox, no image with IE 9
things that seem a bit funny in the x264 settings:
1. vbv values are below the bitrate you had chosen. -> seems to be wrond
2. preset Placebo? I would have gone for some thing faster.
3. why enabled blu-ray compatibility for streaming content? -
seeking is partly function of keyframe interval. Reduce the --keyint setting for better (finer gradations) seeking (in your screenshot it's labelled "keyframe interval" )
vbv values are problematic as selur said above
Don't use open-gop or weightp for flash. There is a decoding bug on linux with firefox (at least there used to be, it might have been patched) -
-> you might want to look for a gui which has some web streaming presets or read up on the x264 settings.
If you want more jumping points configure it to set more key framescan scroll only 3 part of the video: The beginning the middle and the end of the video -
Disable hardware decoding in Adobe's Flash player (you have to exit the player and restart it for the change to take effect).
Or use very short GOPs to minimize the problem. Like --keyint=12 (a half second at 25 fps). That will kill the compression though.Last edited by jagabo; 17th Jan 2013 at 08:45.
How to mplayer video fullscreen and keep original video resolution?
By leandro in forum Software PlayingReplies: 16Last Post: 6th Nov 2012, 11:33 -
HOW CAN I CREATE HW ACCELERATED WEB VIDEO? It is called Adobe "STAGE VIDEO"
By Stears555 in forum Video StreamingReplies: 7Last Post: 24th May 2012, 10:29 -
MPC - Video problems when going fullscreen?
By czeshire in forum Newbie / General discussionsReplies: 4Last Post: 2nd May 2012, 07:02 -
Entering Video Bitrate Makes Preset Switch To SVCD
By akulier in forum ffmpegX general discussionReplies: 7Last Post: 26th Feb 2008, 05:12 -
By akulier in forum ffmpegX bugs and suggestionsReplies: 1Last Post: 21st Feb 2008, 04:31
