Hi,
I have Premier Pro CS4 and importing footage filmed on Samsung HMX-H300SP which is in MP4 format, 720 50p.
When i output it comes out in slow motion. I have tried several different options and settings, can anyone suggest a fix or a plugin?
How are you determining this? Maybe it's a playback problem? (what software, what computer specs) ? Try another video player e.g. vlc, mpchc, smplayer
What FPS was the clip interpreted as ? (right click the clip in the clip bin)
What sequence settings ?
What export settings ? -
Thanks, you mentioned the output settings! DOH! Only thing i hadnt changed, outputted to a different format and all is ok.
THanks
Capturing HD from HDR-HC1E using Adobe Premier Pro CS4
By Beam in forum Camcorders (DV/HDV/AVCHD)Replies: 4Last Post: 6th Jul 2010, 14:36 -
Premier Pro CS4 Crashes during Export
By Don Man in forum EditingReplies: 9Last Post: 26th Jun 2010, 11:35 -
Viewing Problem in CS4 Premiere Pro
By carfyx in forum MacReplies: 2Last Post: 18th Jan 2010, 21:20 -
Premier CS4 and letterboxing?
By beavereater in forum EditingReplies: 2Last Post: 28th Dec 2009, 21:42 -
Problem with CS4 Premier Pro
By Devilish Me in forum EditingReplies: 4Last Post: 12th Mar 2009, 18:06
