  1. vicky
    my chassis fan doesn't work .can someone guess the problem
  2. Member sanlyn's Avatar
    Hm, let's see....how many different models of PC have been manufactured over the last 15 years? Someone might be able to guess which one you have. You might get better advice if you furnish more information.
    In general, however, you should unplug the chassis fan's power cable from the motherboard, buy a new fan that fits, and plug its power cord into the same motherboard power connector you're using now. However, some PC's (usually Dell) require special types of chassis fans.
    Our inventions are wont to be pretty toys, which distract our attention from serious things. They are but improved means to an unimproved end. -- Henry David Thoreau
  3. Member hech54's Avatar
    It's dead?
  4. It's not plugged in?
  5. Member sanlyn's Avatar
    The other possibility is that the PC's power supply is dead.
