I've purchased parts for a new i7 3770k build I'll be using to encode audio and HD video.
Would it be advantageous to use a dedicated video and sound card, or just use the built-in CPU's video and audio off the motherboard? I don't play PC games, so was thinking of just getting an inexpensive < $65 graphics card, and an inexpensive audio card. Would I be wasting my $$$, or would they actually be a good idea?
Thank you in advance for your comments and advice.
-The Mang
cheap boards wouldn't do any good. a $300 up vid card would with a program that supports gpu acceleration would. audio cards don't figure into encoding.
The 3770K's GPU is more than sufficient for regular desktop usage. Since you don't play games there's no need for an add-on graphics card.
If you want GPU encoding the i7 GPU's Quick Sync is faster than any other GPU encoder. But all the GPU encoders deliver inferior quality. You'll find that x264 at fast settings on the 3770k is almost as fast as Quick Sync and still delivers better quality.
Regarding audio, onboard audio is usually fairly good these days. The major problem area is noise. Some motherboard manufacturers don't properly shield and isolate the analog audio circuitry. Try the onboard audio first. If you're not happy with it, upgrade.Last edited by jagabo; 15th Jan 2013 at 22:30.
Dedicated Video conversion PC
By tonyaldr in forum Video ConversionReplies: 14Last Post: 14th Aug 2011, 23:08 -
What video cards support S-Video & Composite output over VGA via adapters?
By Bix in forum ComputerReplies: 5Last Post: 22nd May 2010, 21:57 -
What is the difference between onboard & stand alone video cards ?
By Illusionist in forum ComputerReplies: 18Last Post: 22nd Dec 2009, 19:05 -
Which of the 2 sound cards for games & midi audio files
By retroborg in forum ComputerReplies: 2Last Post: 7th Oct 2008, 13:00 -
Are there any Screen Recorders. that have a built in sound Card?
By hypnoticpimp in forum Video StreamingReplies: 2Last Post: 8th Aug 2008, 21:11
