Hey all! I hope this is in the right place. Basically, I'm going to be traveling across the US conducting interviews, filming scenery, etc. I need suggestions on a great HD camera that's not crazy expensive. Price range 300-900. Once I finish I then want to make short videos of what happened in each state. I can get a new laptop as this is a funded project, but I was wondering what a good software for this is? And if I need a certain requirement from my laptop? I also want to burn some longer length DVD's of the trip. Thanks for any info! It's much appreciated!
Please try include some of your question in the thread title. I changed it for you this time. You can also update it by click edit and go advanced.
No, I can't help you as the last camera I used was a VCR camcorder.... -
Hello,
I will let other more experienced camera enthusiasts recommend cameras, but will say that you may want to consider using a mic other than the onboard camera mic, especially if you will be conducting interviews. Of course, that depends on what your budget is and also what camera you purchase.
Brainiac
Multiple questions on DVD Ripping / Format / Codecs
By mediafan26 in forum DVD RippingReplies: 5Last Post: 14th Apr 2012, 17:17 -
Newbie Conversion questions: combine multiple .m2ts files
By Deku Scrub in forum Blu-ray RippingReplies: 9Last Post: 15th Dec 2009, 19:05 -
multiple questions here so i'm not sure where to put this
By pmmassacre in forum MacReplies: 10Last Post: 12th Jun 2009, 07:49 -
Newb questions - re. HD&MiniDV Camcorders & Capture
By The Big Cheese in forum Camcorders (DV/HDV/AVCHD)Replies: 1Last Post: 1st Jan 2009, 17:21 -
Zen V Plus questions by floundering newb
By Minni in forum AudioReplies: 0Last Post: 20th Feb 2008, 22:24
