    Hey this is probably been talked about before on here but my TV won't play a certain .mkv file but plays every other one I have, I know that It's sometimes the problem of the Format profile, but they look kinda the same. can anyone tell me the difference between the files please?
    Here is a .mkv file my TV will play
    general
    Format                           : Matroska
    File size                        : 12.0 GiB
    Duration                         : 2h 44mn
    Overall bit rate                 : 10.5 Mbps
    Writing application              : mkvmerge v4.1.1 ('Bouncin' Back') built on Jul  3 2010 22:54:08
    Writing library                  : libebml v1.0.0 + libmatroska v1.0
    Video
    Format                           : AVC
    Format/Info                      : Advanced Video Codec
    Format profile                   : High@L4.1
    Format settings, CABAC           : Yes
    Format settings, ReFrames        : 4 frames
    Codec ID                         : V_MPEG4/ISO/AVC
    Duration                         : 2h 44mn
    Bit rate                         : 8 954 Kbps
    Width                            : 1 920 pixels
    Height                           : 1 080 pixels
    Display aspect ratio             : 16:9
    Frame rate                       : 23.976 fps
    Color space                      : YUV
    Chroma subsampling               : 4:2:0
    Bit depth                        : 8 bits
    Scan type                        : Progressive
    Bits/(Pixel*Frame)               : 0.180
    Stream size                      : 10.1 GiB (84%)
    Writing library                  : x264 core 128 r2216 198a7ea
    Encoding settings                : cabac=1 / ref=4 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=8954 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
    Language                         : English
    Audio
    Format                           : DTS
    Format/Info                      : Digital Theater Systems
    Codec ID                         : A_DTS
    Duration                         : 2h 44mn
    Bit rate mode                    : Constant
    Bit rate                         : 1 510 Kbps
    Channel(s)                       : 6 channels
    Channel positions                : Front: L C R, Side: L R, LFE
    Sampling rate                    : 48.0 KHz
    Bit depth                        : 24 bits
    Compression mode                 : Lossy
    Stream size                      : 1.74 GiB (14%)
    Language                         : English
    ...and this is the one that won't play
    General
    Unique ID                        : 254602613258483082126263581681128798119 (0xBF8AADFF77B1A42BABDF7EF9FE7377A7)
    Format                           : Matroska
    File size                        : 13.4 GiB
    Duration                         : 1h 51mn
    Overall bit rate                 : 17.3 Mbps
    Encoded date                     : UTC 2012-11-08 13:34:14
    Writing application              : mkvmerge v4.9.1 ('Ich will') built on Jul 11 2011 23:53:15
    Writing library                  : libebml v1.2.1 + libmatroska v1.1.1
    Cover                            : Yes / Yes / Yes
    Video
    Format                           : AVC
    Format profile                   : High 10@L4.1
    Format settings, ReFrames        : 3 frames
    Muxing mode                      : Header stripping
    Duration                         : 1h 51mn
    Bit rate                         : 15.3 Mbps
    Height                           : 800 pixels
    Display aspect ratio             : 2.40:1
    Color space                      : YUV
    Bit depth                        : 10 bits
    Bits/(Pixel*Frame)               : 0.417
    Stream size                      : 11.9 GiB (89%)
    Language                         : English
    Audio #1
    Format                           : DTS
    Codec ID                         : A_DTS
    Duration                         : 1h 51mn
    Bit depth                        : 24 bits
    Stream size                      : 1.17 GiB (9%)
    Language                         : English
    use mkvmerge and remux the mkv with header stripping turned off. it's in the settings.
    It's 10bit AVC, it won't play because 10bit isn't supported by any common hardware devices, only computer playback. You would have to re-encode
    Thanks to you both, but aedipuss mkvmerge is taking so long to mux now... is that normal?
  5. aBigMeanie aedipuss's Avatar
    no it shouldn't take any longer with header stripping off. that setting should have been the default anyway, as the size savings with it on are miniscule and it won't play on a lot of hardware.
    cancel it. reboot. try again. or not as pdr pointed out it isn't going to play for another reason also.
