It's unbelievable but, while I know that the Space bar starts playing a movie in VirtualDub ("Preview input", actually) I can't find a way to stop it pressing a key.I looked in the "Options > Preferences > Main Keys" list, but the Stop function is not there...
Any hint?
Thanks a lot.
EDIT: (See posts below) I can't find a way to stop (not pause) playback in PotPlayer too. And in the shortcuts customizing menu the Stop function is missing. How can I stop a movie with the keyboard instead of using the usual button with the square icon?
Results 1 to 12 of 12
Falco2000, video newbie.
Let's everyone help each other. -
Humm... just found a way: "ALT+F" (opens the "File" menu) and then "A" (select the "Abort dub" command)...
Pressing the space bar again will stop it.
Yes, "space" = start/stop.
Common to many media players. -
I already tried to press the Space bar again, like I do with every other media player, but it doesn't work for me.
Maybe it's because I used VirtualDubMod and VirtualDubMPEG2 instead of VirtualDub?
Anyway, the "Stop"/"Abort" command is missing in the "Main Keys" list, while the "Preview input" command is included (and it's set on "Space" as primary key)...
I'll be forced to keep on using the "ALT+F and A" keys...Falco2000, video newbie.
Yes, space bar doesn't stop playback in VirtualDubMod. I believe it's a bug. Why are you using it instead of VirtualDub? The only advantage it has is support for multiple audio streams.
Ok thank you.
I can only remember that when, many months ago, I first downloaded VirtualDub, it didn't manage the formats I needed (MPEG-2 and/or MP4), so I installed VirtualDubMPEG2. Then I changed to VirtualDubMod because VirtualDubMPEG2 didn't reproduce audio during playback, while VirtualDubMod did.
Should I switch to VirtualDub again and install some filter/plugin for .MPG (MPEG-2+MP2) and .MP4 (h.264+MP3) management?
Thank you in advance.Falco2000, video newbie.
Thanks a lot Jagabo. Last time I tried to do that the MPEG-2 plug-in webpage was not working but at this time it is.
Another similar question: I can't find a way to stop (not pause) playback in PotPlayer too. And in the shortcuts customizing menu the Stop function is missing. How can I stop a movie with the keyboard instead of using the usual button with the square icon? I can only Play/Pause with the space bar but I often need to totally stop (=close) a movie in order to, for example, change its filename.Falco2000, video newbie.
Can't stop DVD from playback
By maverickluke in forum DVD RippingReplies: 7Last Post: 18th Jan 2011, 02:52 -
Why this poor playback - except VirtualDub?
By terrypin in forum Newbie / General discussionsReplies: 8Last Post: 13th May 2009, 07:09 -
DVR630H - playback stop...
By stepw in forum DVD & Blu-ray RecordersReplies: 6Last Post: 14th Oct 2008, 12:11 -
Playback corrupted in VirtualDub
By terrypin in forum Newbie / General discussionsReplies: 11Last Post: 18th Sep 2008, 03:02 -
Change the key of a song to another key?
By Ikka in forum AudioReplies: 4Last Post: 3rd Feb 2008, 13:27
CTRL+Z flips the pictures horizontally...
