I have a mpeg 2 file that I would like to trim without having to re-encode.
It's a video capture from a tv tuner. I would like to cut off a few minutes from the beginning and at the very end.
I tried avidemux, but it crashes when I try to save; it says the key frames are corrupted for some reason.
Here's the codec information of the file:
Solvieg Video Splitter seams to edit without re-encoding
MPEGVCR and VideoReDo can do this, but VideoReDo's trial version is severely restricted and will likely be useless to the OP unless his file is under 5 minutes long. If I remember correctly, MPEGVCR's trial version is fully functional. I believe that you get what you pay for and the free editors are pretty crappy. If you want to do it right and it's something you'll be doing on a regular basis, buy either MPEGVCR or VideoReDo.
Cann't burn mpg into vcd due to encoding problem!
By MARIGOLD in forum Authoring (VCD/SVCD)Replies: 4Last Post: 1st Oct 2012, 09:08 -
Trim M4V file without re-encoding
By marioval in forum EditingReplies: 2Last Post: 20th Sep 2011, 12:53 -
mpg to vob conversion without re-encoding
By dalek6388 in forum Authoring (DVD)Replies: 4Last Post: 22nd Nov 2010, 16:04 -
How to trim .flv file without re-encoding
By Eye for Video in forum Newbie / General discussionsReplies: 7Last Post: 31st May 2010, 00:01 -
cant trim/cut mpg in QT-pro
By Kevlin in forum MacReplies: 3Last Post: 17th Aug 2008, 13:25
