  1. Member hornetster's Avatar
    Trying to convert files from a video camera (Generic - Kogan branded). The default conversion tool supplied is "on the camera", works in Windows, and will only work while the camera is detected. (A PItA)
    Mediainfo gives me the following info:
    General
    Complete name : /home/Movies/Wedding/Original/FILE0002.AVI
    Format : AVI
    File size : 37.1 MiB
    Duration : 26s 526ms
    Overall bit rate : 11.7 Mbps
    Recorded date : 2012-11-28
    Writing library : AMBA
    ICRT : 12:14:16
    Video
    Format : AVC
    Format profile : Main@L4.2
    Format settings, CABAC : Yes
    Format settings, ReFrames : 4 frames
    Format settings, GOP : M=3, N=15
    Codec ID : H264
    Bit rate mode : Variable
    Bit rate : 11.3 Mbps
    Maximum bit rate : 13.2 Mbps
    Width : 1 280 pixels
    Height : 720 pixels
    Display aspect ratio : 16:9
    Frame rate : 29.970 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.410
    Stream size : 35.8 MiB (97%)
    Audio
    Format : ADPCM
    Codec ID : 11
    Codec ID/Hint : Intel
    Duration : 26s 490ms
    Bit rate mode : Constant
    Bit rate : 384 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Bit depth : 4 bits
    Stream size : 1.22 MiB (3%)
    Interleave, duration : 43 ms (1.28 video frame)
    Am trying to use Linux, and by default ffmpeg, and using the following command: ffmpeg -i $1 -aspect 16:9 -target pal-dvd $1'.mpeg'
    This works, but the final DVD is very jerky and hard to watch...
    Can anyone suggest how I can improve on this?
    Thanks, John.
    Because PAL is 25fps and your source is 29.97fps(NTSC standard framerate). So try convert to NTSC instead. -target ntsc-dvd
    Most dvd players should be able to handle both PAL and NTSC.
