I recently downloaded a few files that were in flv format....ok while watching these files they startoff playing perfect the video and audio is in sync...but i noticed the longer the video plays the more the audio gets ahead of the video and by the end of the files they are way out of sync....does anyone know how to fix this issue?...i know that vlc player and media player classic can change the audio while in the process of watching the file to keep it in sync with the video but i'm looking for a program or a way to fix it and save it so the audio don't keep getting ahead of the video everytime i reopen the files and watch them....i believe the files were like this when i downloaded them cause every player i use i get the same result.....sorry if i posted this in the wrong section...i'm new
Thread: FLV files out of sync
I guess you have tried find a better source because fixing progressive out of sync isssues is not that simple.
But maybe you can make a mkv from the flv using mkvtoolnix and add the stretch by value, see http://www.bunkus.org/videotools/mkvtoolnix/doc/mkvmerge-gui.html#trackoptions . But I'm not sure if it's supported by all video players then.
How to join four .flv files in to one .flv file using ffmpeg?
By spiderMan007 in forum EditingReplies: 3Last Post: 26th Aug 2012, 13:18 -
FLV to AVI when FLV has A/V sync?
By RedPenguin in forum Video ConversionReplies: 3Last Post: 19th Aug 2012, 15:19 -
How To Sync A/V in FLV
By kookie2000 in forum Newbie / General discussionsReplies: 2Last Post: 15th Sep 2010, 03:20 -
FLV audio out of sync, can't work VirtualDub w/ FLV plugin
By ZantarV in forum Video ConversionReplies: 1Last Post: 4th Sep 2009, 11:51 -
Multiple FLV files into 1 big FLV file, how??
By vividbreeze in forum Newbie / General discussionsReplies: 1Last Post: 16th Dec 2008, 15:11
