I was wondering if there was a way to transcode my assets (video files) in Adobe Encore so that when I add additional videos I don't have to revert all to original and re encode them. Currently I have a BD-RE disk that I burn to. I am constantly adding new files to my project and when I attempt to encode the new asset a dialog box pops up announcing that the bit rate is to high and there is not enough disk space, try deleting some files (something along those lines). However I have plenty of disk space. I was told this is because when you encode your project it uses about the maximum amount of space.
What can I do to fix this issue so I only need to encode new files with no issues and reburn the disk.
I don't have this software but sounds like they have some auto setting selected for you. I would search the net for a "manual" bitrate option. Either that or look for some kind of user selected space option where you tell it what you want to use.Originally Posted by kjpolkerDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Mac Hardware for AE and PP CS6
By joobny in forum MacReplies: 0Last Post: 9th Jul 2012, 03:07 -
Help please with After Effects Cs6 and Premier pro
By FUJAU in forum Authoring (DVD)Replies: 2Last Post: 24th Jun 2012, 07:23 -
Transcoding and Adobe Encore
By pc1971 in forum Authoring (DVD)Replies: 1Last Post: 13th Jan 2010, 23:13 -
Adobe Encore and forced transcoding
By juantohu in forum Authoring (DVD)Replies: 4Last Post: 10th Dec 2009, 01:40 -
Different Transcoding on Encore
By htalnts in forum Authoring (DVD)Replies: 1Last Post: 14th May 2008, 22:42
