Hi,
I have an mpeg video (m2v/d2v) with YV12 colorspace and I'm wondering, should I open it in VDub and save it directly to AVI with Lagarith codec BEFORE applying any AviSynth scripts/effects on it?
Or can I just go ahead, open the d2v file, make some changes, and then save it to AVI?
I'm affraid to loss quality, it's an animation.
Any comment is welcome.
It's not necessary - avisynth frameserves uncompressed video
You might want to use a lossless intermedate AFTER, however, if your scripts/filters are slow bottlenecking, and are doing a 2pass encode (the reason is you will encounter the slow filters twice instead of once) -
I'm not sure I fully understand what you're trying to tell me.if your scripts/filters are slow bottlenecking, and are doing a 2pass encode
I feel better now that I know AviSynth serve uncompressed video... even if the image looks more compressed, maybe its my script... :Pavisynth frameserves uncompressed video
Thanks for your help poisondeathray -
1) There are some cases where you might want do multipass encodes (encoding, not talking about avisynth filtering) . You might have fixed capacity constraints (e.g. optical media, blu-ray, maybe need a certain bandwidth for flash) , and a 1pass VBR might produce lower quality than 2 or more passes
2) Some avisynth filters are VEERRRRY SLOOOOOOOOOOWW, even when running MT . They become a processing bottleneck, and you might get very low CPU% usage (= IDLE wasted cycles) .
3) When doing multipass encodes with slow avs scripts, it's faster overall to use a lossless intermediate, then do multipass encode using the lossless intermediate as the source (because that source has that filter chain applied to it)
Doesn't even have to be avisynth - the concept is the same about avoiding bottlenecks with multipasses. Even non avisynth filters like neat video , other denoisers can be very slow. -
VDub is runing at 15% in Highest priority (according to the VDub Status window)...
Yes it is very slow! And I don't use the MT version (yet).
So it is suggested to convert it to Lagarith before applying avs scripts. (If I understand you correctly)
How do I use multipass with VDub and AviSynth? (Right nowI set it to Fast Compresison in the video menu of VDub)
Because I know multipass are much better... but you read my other (long) post about my old animation movie, and now I don't really know in which order I need to do the steps
I may need to burn the video file after to a DVD support for regular DVD player... But I'll keep a copy (size doesn't matter) on my computer.
HC Encoder input file challenge/ AVIsynth script?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 8Last Post: 7th Nov 2011, 21:40 -
Avisynth Script for letterboxed mp4 to mpg?
By Robert Simandl in forum Video ConversionReplies: 1Last Post: 16th Sep 2011, 16:57 -
Avisynth: Append mpg script ?
By zzyzx2 in forum EditingReplies: 4Last Post: 8th May 2010, 16:26 -
Where best to put DG's MSharpen filter in AviSynth script?
By DRP in forum Video ConversionReplies: 2Last Post: 8th Aug 2008, 03:24 -
Saving AviSynth script to file
By Leo48 in forum Newbie / General discussionsReplies: 6Last Post: 24th Jun 2008, 14:35
