  1. I'm trying to capture a poorly dubbed VHS tape into Adobe Premiere CS5 for a video art project that uses generation loss as a visual motif. At certain points on the videotape the signal gets scrambled and breaks up into static. I want to preserve this effect in the capture process but am having difficulty. I've used several capture devices, including a Toshiba DVD Recorder, Canopus ADVC-110 and Blackmagic Design Intensity Extreme, but the image goes black whenever there's any static. I know this effect can be transferred to digital because I've seen several examples on YouTube, like this video: http://www.youtube.com/watch?v=rsDaUlRmYCc&feature=related
    I've considered purchasing a time base corrector but I'm not sure which one would be best or whether it will yield the results that I want. Again, I don't want to clean up the image on the videotape. I want to retain the static and rolling image. Does anyone know what equipment I need to capture this effect? Thanks.
  2. A TBC should definitely do the trick. The best TBC in the Biz is a Hotronic, but that's pricey. There is a small green one you can sometimes find on ebay that usually works well enough.
    It depends on the digital encoding hardware. Some will always mute "bad" sections like you want to capture, others will not. Using a TBC may or may not help.
    This is one of those seemingly-simple puzzles you may not be able to solve quickly: it may take experimentation with different Mac encoder accessories, DVD recorders, TBCs until you hit the combination that works. If you're in a hurry to finish an art project, and don't expect you'll need to do this specific kind of "flaw capture" on a regular basis, cornucopia's suggestion to use a video camera pointed at a screen playing the flawed tape would be the quick n dirty, but guaranteed, way to do it.
