Hello.
I'm using a Canopus AVDC 110 to capture Hi-8 tapes. I also have a small, blue gun equipped video monitor (Panasonic BTS901Y 9") and a Hotronic AP-31 TBC that I'd like to use to -hopefully- improve the quality of the captured video.
Here's what I think is true: from the source VCR (camcorder actually) the signal should go through the TBC and then to monitor, and then the AVDC 110.
Questions -
If I split the signal after the TBC and run one to the video monitor and one to the AVDC 110 will there be a problem with signal strength?
Am I right that I should run a test signal through the TBC to adjust it before capturing?
If so, is the monitor sufficient for judging any adjustments to be made to the signal by the TBC - for example, by running color bars through the TBC and viewing them with the blue gun on the monitor?
Or do I also need some kind of waveform monitor/vectorscope?
If so, do you think I should go with a hardware or software waveform/vectorscope? ( I use Mac + Final Cut Express )
Big questions. Thanks for your help!
John
I don't see the point of the monitor for video since all should appear at the display from the advc.
But if you want to use this and split the video signal then there is IMO likely to be signal loss unless you use an active (powered) splitter. -
What you see on a TV monitor (with respect to TBC performance) is irrelevant - it's how the ADVC captures it post-TBC that matters. Check the preview on the PC.
Digitizing VHS Inefficiency Question
By megasaja in forum CapturingReplies: 48Last Post: 31st Jul 2012, 08:21 -
TBC question
By Petergar in forum DVB / HDTVReplies: 1Last Post: 21st Apr 2011, 07:45 -
Incorporate a light weight browser in an LG BD-390
By wschomburg in forum Video StreamingReplies: 1Last Post: 12th Dec 2010, 21:17 -
TBC suggestions: TBC-1000, AVT-8710, ADVC-300, TV1-TBC, or TV1-TBC-GL
By m27315 in forum RestorationReplies: 16Last Post: 24th Mar 2010, 01:36 -
JVC HR-S9800U TBC question
By moondogger in forum CapturingReplies: 10Last Post: 4th Aug 2009, 21:14
