Hello everyone,
I'm trying to use AVI2DVD to convert an .MP4 file for burning to a DVD. The original input file was in .MP4 format but when I tried to run it through AVI2DVD, an error popped up saying " interface not supported" and AVI2DVD would lock up. I then ran the same input file through Format Factory to convert it to an AVI file and tried running that through AVI2DVD using QUenc but got an error that read: "AVI2DVD error:"AiSynth open failure. AVIsource: could not decompres keyframe 6".I tried googling that error message but didn't come up with much. I tried again this time using HCenc and got the following error message
"[4:26:46 PM] AVI2DVD Started !
[4:26:48 PM] Type mode : Avi Input
[4:26:48 PM] Output : Dvd
[4:26:48 PM] Encoder Selected : HCEnc
[4:26:48 PM] Start demuxing the AudioStream No.1 ...
[4:27:45 PM] Demuxing of the selected audio finished
successfully ! [C:\Users\Dan\Desktop\Avi2dvd_temp
\Extracted_Audio.mp3 111014974 Bytes]
[4:27:45 PM] Starts Audio correction ...
[4:27:57 PM] Audio Fixed successfully ! [C:\Users\Dan
\Desktop\Avi2dvd_temp\Fixed_Audio01.mp3 111014974
Bytes]
[4:27:57 PM] Starts Mp3->Ac3 convertion ...
[4:32:38 PM] Audio converted in Ac3 successfully ! [C:
\Users\Dan\Desktop\Avi2dvd_temp\AudioStream 1 MP3
2CH.ac3 333043200 Bytes]
[4:32:38 PM] Start creating avisynth script ...
[4:32:38 PM] Avisynth script created successfully ! [C:
\Avisynth_Script_File.avs 170 Bytes]
[4:32:39 PM] Bitrate used : 4776 Kbpps
[4:32:39 PM] Start video encoding ...
[4:32:52 PM] Video encoded successfully ! [C:\Users\Dan
\Desktop\Avi2dvd_temp\Encoded_Video.m2v 0 Bytes]
[4:32:52 PM] Job NOT Done. There are warnings ... Find at
the log file the 0 byte generated file to focus where exactly
the problem appears"
As far as the settings go, the aspect ratio is always set to 16/9, there's only one audio stream to choose from, output is set to "DVD or SVD", disk size is DVD-5, audio bit rate 384, chapter every 15 mins. And I have "make ISO" checked off. The HCEnc settings are "best" and " MPEG". I'm trying to create this DVD without menus.
Any idea what could be causing these problems? I've used AVI2DVD successfully before but started having problems a few weeks ago so I tried uninstalling/reinstalling it but I'm still having these problems. I was finally able to use DVDflick to successfully burn the AVI file to a DVD but got lucky there as most times I've used DVDflick before, the audio was always out of sync with the video. Thanks in advance for any help you can provide.
Results 1 to 1 of 1
Dan in CT
iWisoft Free Video Converter producing blank (black) video?
By avideodummy in forum EditingReplies: 0Last Post: 23rd Aug 2011, 15:26 -
How to stop Explorer from locking video files?
By Djard in forum Newbie / General discussionsReplies: 25Last Post: 14th May 2011, 02:24 -
How do you stop Explorer from locking video files?
By Djard in forum Newbie / General discussionsReplies: 2Last Post: 2nd May 2011, 01:49 -
KMPlayer took over all my video files, having trouble with AVI2DVD now
By kwik in forum Newbie / General discussionsReplies: 12Last Post: 4th May 2009, 12:25 -
Virtualdub Producing Massive AVI Files
By DaMasteRZ in forum Video ConversionReplies: 5Last Post: 23rd Aug 2008, 23:37
