Hi, I've been doing some vhs captures with my svhs unit (JVC SR-V101US) for a while now without any trouble until recently. The issue I'm having is that some kind of noise happen when a vhs tape is rolling during capture. I dont know what's causing this, but I know that it doesn't apear at the the same places (whem playing the tapes) and that the issue is gone momentarilly when I'm plugging and unplugging the rca cable (which has been replaced 3 times this week) and when I eject the vhs to put it back in the vcr. I tried to play some the same tapes on another unit (Panasonic AG-W3) and the issue is no longer there. I did the same with a Sanyo unit (VHR-H532) with the same results with the Panasonic. So, what could be causing this ? I've thought that the JVC unit might need a good internal clean up, but I prefer to ask some advices to some of the experts here (Lordsmurf & all) before doing so.
Here's an audio sample to download so you can hear (7zip file). Let's hope that this issie can be solved.
Thanks to answer as soon as possible
Results 1 to 14 of 14
Thread: Sound problem during vhs capture
You have NOT attached an audio sample. Try again.
hech54, go back read my message carefully.
mike20021969, I'll try to check on the tracking control and let you know if that's it or not. -
Thanks mike.
ok, I've tryed the tracking control but excepting the image, I didn't see much change on the sound though... I'll try later with anothe tape, see if it gets the same results. -
Me again. I tryed another tape and ajusting the tracking control, but no success. I don't know what's triggering the reagtion, but one of the consequences is the fact that the audio keep changing mode at times (hi-fi to normal). So seriously, I dont know. Can the fact that some pieces inside this unit trigger the reaction because they ar dirty ? Any ideas ?
Thanks to answerLast edited by monks19; 5th Jan 2013 at 22:31.
It's probably time to open up the VCR and clean the (entire) tape path with isopropyl alcohol and an appropriate applicator (I use numerous cotton buds to apply, clean and polish stationary heads, guides and capstan - but never use cotton buds on the drum heads). Pay special attention to the stationary heads. All it takes is a speck of dirt to mess up playback.
If things don't improve, it maybe time for a professional service, or possibly new drum heads or another machine.Last edited by mike20021969; 6th Jan 2013 at 04:16.
On VHS decks, hi-fi audio is recorded & played back by separate audio heads that spin on the drum along with the video heads. It is therefore possible for video to track perfectly but hi-fi audio to rattle and/or cut in and out, or vice-versa. Although VHS track dimensions are much bigger and longer than, say, those on 8mm tapes, compatibility issues can still arise between tapes being played on machines that didn't record them. These machines may have problems on the extreme: worn out or very dirty pinch rollers & idler wheels, tape guide paths that have been ever so slightly gouged out, dirty video heads and hi-fi AND normal audio heads. There are natural breaks in a video signal such as horizontal and vertical blanking where video head construction can be made to coincide with as they spin and so playback appears smooth. For hi-fi audio though, audio is broken & reconnected 60 clips a second; there is circuitry that mutes these joints and should ideally switch from one head to the next seamlessly. Ever so slightly misaligned audio & video heads (in relation to one another) because of any of the reasons I mentioned above can cause this circuitry to not mute and we hear the motorboating sound (actually a series of spikes at 60Hz). Even worse, there is another circuit that switches between hi-fi and normal tracks (depending on the condition or presence or absence of any of them) that compounds the problem. Video & hi-fi audio heads are fragile and can be destroyed by sledgehammer-fingered people, but that shouldn't prevent them from being cleaned manually, along with everything on the tape path, applying dragonfly-like delicacy. I'd get a piece of paper for example, douse it in isopropyl alcohol, set it against a rotating head, and manually twist them against the paper. A plastic knife can be used to scrape off built-up oxide on stationary heads (normal audio & control) and rollers. It could be done simple in the past, but VHS tape cleaners have gone extinct.
What you don't know won't hurt you.
Until it hurts you. Then you know.
Please help! Problem with using TBC to capture VHS tapes.
By jrodefeld in forum CapturingReplies: 9Last Post: 9th Jun 2011, 17:08 -
vhs video capture bad sound
By lulu15 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Mar 2011, 20:59 -
Very strange VHS to PC capture problem
By fredhoward in forum CapturingReplies: 45Last Post: 9th Feb 2010, 08:30 -
VHS Capture Problem
By sdculp in forum Newbie / General discussionsReplies: 7Last Post: 15th Nov 2008, 08:58 -
Help with VHS -> DVD using capture card (audio problem)
By dustin1 in forum Newbie / General discussionsReplies: 20Last Post: 7th Feb 2008, 23:27
