I am looking to buy a box set of all seasons of the old TV series the six million dollar man......However before I take the plunge and spend £120.....The Item is listed as REGION 2 but in in the title it states NTSC. Does this present any problems ?.....the reviews of the item proclaim the picture is excellent due to them being re-mastered, but i dot want to buy the item and find it has that stuttering effect during action scenes that I have noticed on some region 1 poorly mastered tv show DVD's..... I hope this makes a little sense to you learned chaps
http://www.amazon.co.uk/The-Six-Million-Dollar-Man/dp/B005ZSHAP0/ref=sr_1_1?ie=UTF8&qi...7334790&sr=8-1
Thread: Region 2 NTSC confusion
Almost all PAL DVD players have no problems at all with NTSC DVDs. I did notice one commenter complaining about one year of the series playing jerky during panning scenes. I don't know if that's a problem with his DVD player, his TV set, or just that particular year of the series. The odds are good (a better than 95% chance, maybe?) of you having no problems at all.
Amazon takes returns. Get it, test out that Season 3 right away, and if there are any problems return the set if you like. My guess is you won't have any problems. All of those leaving reviews are also from Britain or other PAL countries, I think, and they didn't notice any issues with the set (except for the price). -
Thanks for the reply most appreciated.......!!!
Converting DVDs from Region 1 (NTSC) to Region 2 (PAL)
By Astronautilus in forum Authoring (DVD)Replies: 8Last Post: 10th Feb 2012, 04:35 -
Convert PAL Region 2 DVD to NTSC Region-Free DVD?
By wizoomer95 in forum Video ConversionReplies: 6Last Post: 6th Aug 2011, 21:10 -
players for UK, ntsc or multi-region
By mbernard in forum Newbie / General discussionsReplies: 2Last Post: 27th Jul 2010, 09:53 -
Samsung DVD-V9800 region hack confusion, misunderstanding?
By AlbertTheSon in forum DVD & Blu-ray PlayersReplies: 1Last Post: 5th Jan 2009, 19:42 -
Converting PAL Region 2 to NTSC region 1
By bevluvsrats in forum Video ConversionReplies: 10Last Post: 21st May 2008, 09:15
