hi,
I have a problem with this software. in win 7 when I open sup files, some lines some lines have background and some of them have not. I mean some lines are not transparent. I cheked this sup files in win xp and I saw everything was correct and all the lines were transparent. does any body have a solution for this problem?![]()
Thread: Subtitle Creator Problem
Hi ariyan,
I had the same issue. Check the below thread.
http://forum.videohelp.com/threads/351949-How-to-convert-SUP-to-idx-sub
Regards,
Mouna. -
Hi. I have the same problem like ariyan, and that thread doesn't help. I've tried a bunch of stuff's and no results. I've upgrade my win, all the software's, clear the registry, and reinstaled subtitlecreator and the problem is still there. Can't find any result. However if you leave the background when you open the sup file for sync and chek it when you manipulate sup and apply to all it's disapearing but the subtitle font it's a little bit shady. I am waiting for some solution, i don't have any ideas anymore.
problem with Subtitle Creator
By heof in forum SubtitleReplies: 12Last Post: 17th Jul 2010, 01:14 -
Problem with subtitle creator 2.2
By ashkan_vpm2 in forum SubtitleReplies: 0Last Post: 1st May 2010, 17:43 -
Subtitle Creator - Unable to set Default Subtitle Colors & Default Prof
By blue2 in forum Authoring (DVD)Replies: 2Last Post: 15th Nov 2009, 22:47 -
Subtitle colours in subtitle creator
By Belfour in forum SubtitleReplies: 3Last Post: 22nd Oct 2009, 02:00 -
Problem -Subtitling using Subtitle Creator DVD from Multi Volume DIVX Movie
By shotokan101 in forum SubtitleReplies: 0Last Post: 4th Jan 2009, 10:43
