Closed Thread
  1. Hi everyone. I'm here begging for help.
    I'm posting two MediaInfo files below. Can anyone tell me why my Samsung TV (UN40ES6800) plays the first file and not the second? And is there a way to convert the second one so it can be played just like the first one?
    1
    General
    Unique ID : 179514619727717723336376123774877987498 (0x870D4216B3755F5C8EE23E638F4E72AA)
    Complete name : E:\Pelis\Tested\Watchmen 1080p.mkv
    Format : Matroska
    Format version : Version 4 / Version 2
    File size : 6.73 GiB
    Duration : 2h 42mn
    Overall bit rate : 5 942 Kbps
    Encoded date : UTC 2010-02-22 21:41:31
    Writing application : mkvmerge v5.9.0 ('On The Loose') built on Dec 9 2012 15:37:01
    Writing library : libebml v1.3.0 + libmatroska v1.4.0
    Video
    Format : AVC
    Format profile : High@L5.0
    Format settings, CABAC : Yes
    Format settings, ReFrames : 7 frames
    Muxing mode : Header stripping
    Codec ID : V_MPEG4/ISO/AVC
    Duration : 2h 42mn
    Bit rate : 5 200 Kbps
    Width : 1 920 pixels
    Height : 800 pixels
    Display aspect ratio : 2.40:1
    Frame rate mode : Constant
    Frame rate : 23.976 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.141
    Stream size : 5.74 GiB (85%)
    Writing library : x264 core 119
    Encoding settings : cabac=1 / ref=7 / deblock=1:-3:-3 / analyse=0x3:0x133 / me=umh / subme=11 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=64 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=8 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=100 / rc=2pass / mbtree=1 / bitrate=5200 / ratetol=1.0 / qcomp=0.60 / qpmin=3 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
    Language : English
    Default : Yes
    Forced : No
    Color primaries : BT.709
    Transfer characteristics : BT.709
    Matrix coefficients : BT.709
    Audio
    Format : DTS
    Format/Info : Digital Theater Systems
    Mode : 16
    Format settings, Endianness : Big
    Codec ID : A_DTS
    Duration : 2h 42mn
    Bit rate mode : Constant
    Bit rate : 755 Kbps
    Channel(s) : 6 channels
    Channel positions : Front: L C R, Side: L R, LFE
    Sampling rate : 48.0 KHz
    Bit depth : 24 bits
    Compression mode : Lossy
    Stream size : 875 MiB (13%)
    Language : English
    Default : Yes
    Forced : No
    2
    General
    Unique ID : 232476813713800253917135218702640934950 (0xAEE567DB58BD660CA77A2103B73AF026)
    Complete name : E:\Pelis\The Avengers (2012) BDRip 1080p DTS multisub HighCode-PHD.mkv
    Format : Matroska
    Format version : Version 2
    File size : 6.76 GiB
    Duration : 2h 22mn
    Overall bit rate : 6 771 Kbps
    Encoded date : UTC 2012-11-16 17:08:54
    Writing application : mkvmerge v4.8.0 ('I Got The...') built on May 24 2011 03:12:58
    Writing library : libebml v1.2.0 + libmatroska v1.1.0
    Video
    Format : AVC
    Format settings, ReFrames : 6 frames
    Duration : 2h 22mn
    Bit rate : 6 000 Kbps
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Color space : YUV
    Bit depth : 8 bits
    Bits/(Pixel*Frame) : 0.121
    Stream size : 5.87 GiB (87%)
    Title : The Avengers (2012) BDRip 1080p DTS multisub HighCode-PHD
    Writing library : x264 core 120
    Encoding settings : cabac=1 / ref=6 / deblock=1:-3:-3 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / psy_rd=0.80:0.00 / mixed_ref=1 / me_range=64 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=8 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=100 / rc=2pass / mbtree=1 / bitrate=6000 / ratetol=1.0 / qcomp=0.60 / qpmin=3 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:2.00
    Language : English
    Default : Yes
    Forced : No
    Audio
    Format : DTS
    Mode : 16
    Codec ID : A_DTS
    Duration : 2h 22mn
    Bit rate : 755 Kbps
    Bit depth : 24 bits
    Delay relative to video : 22ms
    Stream size : 771 MiB (11%)
    Language : English
    Default : Yes
    Forced : No
    Thanks in advance for any light you can shed.
    Please don't discuss warez releases. Buy your movie and rip to mkv yourself.
