What is a simple program that I can use to adjust the brightness of a DVD clip ( Extracted from a DVD using DVDShrink....) and then output it in the same format, so that I can then use my trusty VideoReDo to edit the clip to get the segments I want, and then convert it for my Ipad2 using good old Handbrake.... I have tried using Video Enhancer but however way i do it the video output stutters or freezes![]()
Thread: adjusting brightness help
great advice, I already had it on my pc but have never though to use it in that manner.........Thanks!! BTW the output file has a slight out of sync audio problem, is there a setting to sort that or is it a long process to sort it ?
DVD Shrink's ripper hasn't been updated in years. Neither has DVD Decrypter's, but you can use DVD Decrypter to rip in IFO mode (this is NOT the same thing as ISO mode - be careful) and create one giant VOB file that you can edit or process as you wish. It shouldn't end up out of synch that way.
Note that there is always some small chance that DVD Decrypter won't be able to rip a DVD you have, but this is very unlikely for DVDs made outside of region 1 and if DVD Decrypter can't handle it, DVD Shrink probably won't either. But you're unlikely to encounter this with region 2 DVDs. -
Thanks for the info, its very much appreciated!!!
adjusting encoding rate dynamiclly
By fengruoyun in forum Portable VideoReplies: 0Last Post: 6th Jul 2012, 03:39 -
Adjusting the INPUT video???
By pooksahib in forum Video ConversionReplies: 4Last Post: 10th Jan 2011, 00:55 -
Adjusting vobsubs for new AR?
By Xavier in forum SubtitleReplies: 1Last Post: 4th Mar 2009, 11:41 -
Adjusting amount of light
By ProducerHarley in forum Camcorders (DV/HDV/AVCHD)Replies: 1Last Post: 28th Jan 2009, 18:07 -
Adjusting Playback speed?
By Scav2003 in forum MacReplies: 3Last Post: 27th Feb 2008, 11:57
