Results 1 to 10 of 10
  1. Hello all, it is good to be here.
    Please read this post thoroughly prior to making a reply.
    PROBLEM:
    Video file has two audio tracks, and the wrong one is the primary.(file details below)
    LIMITATIONS:
    NO V/Dub Mod.
    Computer details:
    New and kick-ass. Win7Ultimate-32/8GB RAM(4 usable)/30 TB RAID/Core i7/Nvidia Tesla x2 in SLI
    File details from G-Spot:
    File has Portuguese as primary audio track. English is secondary.
    DESIRED OUTCOME:
    English audio track is primary/singular.
    Suggestions, please.
    Thank you.
    Try avimuxgui.
  3. use AviMux-Gui:
    1. start AviMux-Gui
    2. drag&drop the file into it
    3. select you video in AviMux-Gui
    4. press 'generate data source from files'
    5. remove the check mark before the audio stream you don't want
    6. press start, enter a new name for the file
  4. This program must be run in compatibility mode for WinXPSP3 to work in Win7-32----just a note
  5. Followed process exactly, except for the drag-and-drop thing....had to use the RC dialog under win 7....did not work. Output file has same characteristics as original. (at least, the same undesirable characteristic) Side note: After opening the file and generating source, path to file is in blue text. Once the audio track is deselected, the path text turns red.
  6. Strange,.. thought that I used it on Win7 a few days ago, just tested got the same problem here,...
    Another option would be AviDemux:
    1. Start it
    2. load your source
    3. select the audio you want to keep under Audio->MainTrack
    4. Save the Audio under a new name
  7. Member hech54's Avatar
    I must be either blind or I haven't used GSpot for a long time.....where in those screenshots does it show/prove that this file has two audio tracks?
  8. Got it to work, thank you. Here's how:
    1. start AviMux-Gui in compatibility mode for WinXP-SP3
    2. Right-click in Open Files field.
    3. select your video in AviMux-Gui
    5. Uncheck "All Audio Streams" and "All Subtitles"
    6. remove the check mark before the audio stream you don't want
    7. press start, enter a new name for the file
    Thank you very much for all your help. Cheers!
  9. Originally Posted by hech54 View Post
    It doesn't. It just shows the codec/container and such. I think we can take my word for it that the problem I signed up for an account to post about is really happening! LoL. Just taking the piss out of you, mate.
  10. Incidentally, I was also able to figure it out with AVIDemux. Here's how:
    1. Start it
    2. load your source
    3. Nav Audio>Select Track
    4. In dropdowns for audio tracks, set the top one as track 1, and the bottom as track 0.
    4. Save the file under a new name
    Using this method, it was not even necessary to remove the Portuguese track. Thank you very much.
