I use TSMUXER to turn MKV files into BD Folder Structures for fast burning to Blu-ray Discs to play in my blu-ray player. The problem is that TSMUXER doesn't support AVI files. I know I could use converters and such but it just takes way too much time for this and I love how fast TSMUXER is. I'm going to get a Media Player soon for my TV to make life easier but until then, anyone know of any software like TSMUXER that supports AVI? I tried using AVI MUX GUI and it turns the movie into an MKV, but TSMUXER won't accept it.
Bottomline I just want the fastest way to turn AVI/MKV into BD Folder structures to burn to blu-ray discs.
Is the avi blu-ray compliant? H264 video, etc?
I doubt that so you must rencovert then.
Or your player probably supports the avi if it's divx/xvid.
Identify the avi properties with mediainfo. -
The codec is XVID. So TSMUXER doesn't support the XVID codec or AVI container. What are my options for the fastest way to burn AVI to BD files? Or am I stuck finding some slow converter to re-encode the video?
You must reconvert if you want a real blu-ray.
See http://www.videohelp.com/tools/sections/all-in-one-blu-ray-converters
But many media players support avi xvid...so do you have to convert? -
I don't have a Media Player for my TV yet, just a Panasonic 3D Blu-Ray player. I did some research and apparently the model I have is suppose to read MKV files but it won't even read that unless I'm doing something wrong. I did a test run with an AVI and MKV file, I stuck them in a folder called BDMV, burned that folder using IMGBURN and all the right settings for a Blu-Ray disc and it didn't work. Not sure if I'm doing something wrong or the blu-ray player just doesn't support the format.
The model number for my blu-ray player is SA-BTT270.
Is there a program similar to TMPGEnc for .mp4 and .mkv files?
By Shinjikun in forum Newbie / General discussionsReplies: 5Last Post: 9th Sep 2012, 14:15 -
Mac audio program similar to BeSweet?
By bgart13 in forum MacReplies: 2Last Post: 26th Jan 2011, 05:44 -
How do you extract ac3 from m2ts when tsmuxer doesn't read the audio?
By yoda313 in forum AudioReplies: 6Last Post: 1st Jan 2011, 08:28 -
Does multiavchd or tsmuxer support .tp files as input sources?
By yoda313 in forum Video ConversionReplies: 8Last Post: 8th May 2010, 08:08 -
AVI won't play. VLC say's doesn't support "IV50" Format. All codecs present
By Sikander in forum Software PlayingReplies: 2Last Post: 21st Feb 2010, 07:40
