  1. I bought Merline pocket HDD to play movies in it
    I have around 100+ DVD movies i want to convert them to MP4 with all audio tracks and subtitle if possible
    also i want to keep the video quality is the best
    if its impossible with MP4 whats a better extension?
    The name of your product is Merlin, not Merline. I looked it up and it supports VOB. I'd suggest just ripping your DVDs to VOB files. You don't say where you live but if you live outside of the USA and Canada then the old DVD Decrypter will probably work fine to rip your DVDs to VOB files. Use the IFO setting. Please note that I said IFO and I did not say ISO. Do NOT confuse them. You can look online for guides on how to rip in IFO mode with DVD Decrypter.
    If you must convert to MP4 then look at Xvid4PSP. Many people use Handbrake but it seems to have problems with some subtitles so Xvid4PSP is a better choice for your needs.
  3. Yes it support many extension AVI, MPEG4, Xvid, Divix, MPEG2, VOB, MPEG1, DAT
    i want to convert them in way no vob no menu, just go to the folder i find one file the movie then play
    can you help me in that ?
    You rip the movies to one giant VOB file by using IFO mode in DVD Decrypter and changing the settings (under Tools) to not split files when ripping. The VOB file will have the best quality you can get because it is the exact contents of the DVD. There will be no menus with the VOB file. You just have the player play it. Why don't you try it and see what you think?
    Here is one guide:
    http://home.derekware.com/dvd/
  5. OK i did follow the guide
    it gave me one VOB file with the full movie its good but whenever i want to change audio in the HDD it wont, in my computer i can change the language why is that?
    i want to ask you whats the difference when i chose between "Direct copy" "Demux" ?
    because when i choice demux it gave me many other files
  6. All i want one vob file contains all tracks and subtitle original from DVD without converting or anything to play it in my pocket HDD, DVD Decrypter did that and itry it in my HDD but it wont show other audio tracks but in my PC it shows them
    because if i have 100+ DVD and every file has more than 1 tracks it terrible
    i need help
  7. it works
    all i did change file mode
    then change settings of file mode to take main movie and ifo
    then change to split file to none
    voila 1 ifo file and 1 vob file with all audio tracks and subtitle
    i hope this helps people
