I've got the EZcap with Windows xp, 1.6Ghz cpu and typically get these kinds of audio artifacts (kind of popping).
Not too serious, but certainly not professional grade audio quality. I don't know what is causing the audio artifacts, but I could
1) update the capture device driver
2) use another capture program instead of Arcsoft
3) instead of running the audio into the capture device, run the audio into the mic jack.
However, I can't seem to turn the mic gain down low enough to avoid loud distorted audio. Also it is a bit of a hassle to change the settings to run the the audio into the mic jack.
Any ideas on how I can eliminate these audio artifacts? I have attached a 40 second video clip.
the audio should go into the "line in" port not the mic port, they have different levels and mic in won't work.
Why do you need an audio "line in"?
http://www.ezcap.tv/usb-video-capture/ezcap116-capture-card
you don't if it's a real ezcap. the red/white inputs to the device should be fine.
Someone said the "clicking" sound in the audio is due to poorly written software, the capture device driver software that is.
He said the clicking sound has something to do with "software interrupts". Does anybody have any idea about so called "software interrupts"? -
You can find the latest drivers for the REAL EZCap here:
http://www.ezcap.tv/ezcap116-drivers
Possible to listen to BDRebuilder audio streams before encode?
By Killingtime01 in forum Blu-ray RippingReplies: 3Last Post: 19th Mar 2011, 10:04 -
listen dual audio same time
By wmpatterson in forum Newbie / General discussionsReplies: 1Last Post: 17th Jun 2010, 16:03 -
Problem with artifacts when encoding to FLV using ffmpegX
By Leon_Cych in forum ffmpegX general discussionReplies: 2Last Post: 30th Apr 2010, 07:57 -
Problem w/artifacts using Thalen DeShaker in Virtualdub
By brassplyer in forum RestorationReplies: 113Last Post: 29th Apr 2010, 06:24 -
DVD Audio Extractor can't listen audio preview
By lupio in forum AudioReplies: 8Last Post: 26th Apr 2010, 11:51
