I have a Dell Inspiron i3, dual core, 2.53 Ghz each, and 2.87 GB usable RAM, Windows 7 64-bit OS.
I want to know if I can watch a movie on VLC while DVDFlick is encoding at "below normal" priority
and "thread count" is set to 2.
Will the encoding be affected or will it slowdown considerably?
I'm a MEGA
Super Moderator
Try???
The encoding quality wont be affected....just the encoding time. How much depends on the video source you are playing and if you are using graphic hardware acceleration/overlay.
I suspect vlc playback quality might suffer. But the encoding quality, no. It'll just take a lot longer.
Thanks Baldrick and Hoser Rob. Yes, you were right, the encoding took longer. I don't think the quality was affected.
Why would the encoding quality suffer? Encoding is like any other non-realtime process. You wouldn't expect your spreadsheet calculations to be wrong while watching a movie, would you? Or your word document to be all messed up? Adding 2+2 will give 4 whether it's performed in a nanosecond or one second. If that isn't true on a system there is something seriously wrong with it.
The type of processes that suffer are realtime processes. Video capture, for example. A new frame of video arrives every 33 ms (at 30 fps). If the CPU isn't available to handle the frame it may be lost.
I agree jagabo, I do my find my question to be silly. Its just going to take longer, the calculation will take some more time as it waits for a free CPU cycle. How stupid of me!
But then what happens when you are doing something CPU intensive (like watching a movie or encoding a DVD using DVDFlick at "above normal" priority) and burning a DVD using ImgBurn? Since movie data has to be transferred to a buffer and then written to DVD which is spinning at a particular rate, if the data are not made available fast enough, then would it be correct to expect errors while burning? Or will the spinning of the DVD be slowed down to cope with less numbers of data being available to burn?
In simpler words, is DVD burning a real time process, dependent upon timely availability of data?
Possibly, burning a DVD is a realtime process.
DVD burners have ways of dealing with this. Basically, they pause the burning process until more data is available. But it's safest not to rely on that.
Thank You!
By Sierraguy in forum Video Streaming
Last Post: 7th Jul 2010, 23:55
By Information in forum Video Conversion
Last Post: 9th Nov 2009, 07:35
By fvisagie in forum Authoring (DVD)
Last Post: 10th Jul 2009, 11:35
By mazinz in forum Computer
Last Post: 29th Apr 2009, 17:27
By mn072065 in forum Computer
Last Post: 24th Mar 2009, 19:59
