I have been using AVISynth for a few years and still cannot get used to all the myriad of filters. New ones seem to be written all the time. It is hard to pick the right one.
I have been experimenting with various filters and scripts.
I capture old VHS tapes via a CANOPUS ADVC 300 then onto the hard disk as an AVI.
I cut it up using VirtualDub - it is easy to operate to remove the noise. I use the DeShaker filter.
I test the scripts using AVSPMod with varying success and I intend to use Sony Vegas Pro or MEGUI to encode it.
I scour the Net, particularly Wikimedia, Doom9 and Videohelp - trying them out.
My question is - is there a bunch of (AVIsynth or VirtualDub) filters that would do the best job?
My VHS has blotchy, unfocused colors, and vague edges. Also annoying horizontal lines that make objects shimmer.
I have solved the problem of cropping (letterboxing) and Trimming.
My videos are quite interlaced.
I find that SeeSaw or Convolution 3D is a start.
Does anyone have any reliable up-to-date scripts that they would recommend? Are there any special arguments for these scripts. I would apppreciate any protocols.
Thanks in advance
No idea where to start. Your workflow seems rather odd (begin with cuts in Virtualub, likely with improper colorspace conversion) then more conversions in Avisynth using filters designed for progressive video, and so forth. Removing noise with DeShaker ?? (it's not a denoiser).
Good idea to begin by finding the reason for "blotchy, unfocused colors, and vague edges" as well as "annoying horizontal lines that make objects shimmer" in your captures. None of the filters you mentioned would adequately address those issues.
Why are you cropping? What is your desired final output? Other than your capture card, what other playback gear are you using and what specific type of "AVI", colorspace, compression, etc., are you copying into? Can't be at all specific without more info and a short video sample.Last edited by sanlyn; 31st Dec 2012 at 15:25.
Our inventions are wont to be pretty toys, which distract our attention from serious things. They are but improved means to an unimproved end. -- Henry David Thoreau -
Sorry. I meant I use DeShaker to stop the Shake in my relative's Video.
I am going to need to be better informed about colorspaces. I began my video editing using MEGUI and used it for cropping and removing tape scratch at the bottom of my videos. Then I wanted to import some AVISynth filters into MEGUI with varying success (crashes). I was configuring MEGUI to x264 and saving it as MKV (x264: ENOEWO_SLOW preset). I then discovered RipBot264 but prefer MEGUI.
Specifically I use MEGUI to crop left, right, top and bottom.
My desire for my final output would be a clear, steady video. The fiobjects in the video I have are very badly defined.
Please find my short video. It is badly interlaced and shaky with scratchy horizontal lines and fuzzy figures.
Best UK PAL VHS / D-VHS machines for digitising old VHS tapes
By pauldsc in forum RestorationReplies: 8Last Post: 6th Jan 2012, 09:21 -
DVHS VCR performance with EP speed tapes and VHS-C tapes?
By NJRoadfan in forum RestorationReplies: 13Last Post: 8th Apr 2011, 20:36 -
Which filters I should use for this anime? (avisynth)
By Cloudstrifeff7 in forum Newbie / General discussionsReplies: 1Last Post: 29th Dec 2010, 12:32 -
By Cloudstrifeff7 in forum Newbie / General discussionsReplies: 6Last Post: 13th Dec 2010, 07:47 -
A little help with VHS color correction and filtering?
By mark23 in forum RestorationReplies: 20Last Post: 2nd Jul 2009, 12:22
