Hello all...first off....wow! what a wealth of information here! As a new guy, am a tad overwhelmed by it all, but thank you for a great site.
Have a Sony minidv cam that i record in 1080i. I have about 30-40 tapes. I would like to edit some and put on a disc to send out to family that live outside my area.
The files are tremendous!
Question: How can i download say 5 tapes or so and then edit them? 2minutes of tape is like 400+mb. I cant transfer 60 minute tapes at that rate!
Thread: MiniDV HD Files to PC
5 tapes is about 65GB. If you don't have that available, really twice that, preferably on a non-system drive, You aren't realistically prepared to do this project. Sorry to be a meanie.
What NLE are you planning to use? -
your computer specs you list contain a 2tb drive and a 1tb drive with assorted others, there has to be plenty of space. tapes take an hour to capture and use 13gb. no other choice.
Also, BTW, what you have there is NOT a DV cam, but an HDV cam. Consumer DV is SD only, HDV is HD (hence the name).
If you are planning on getting them to DVDs, think of starting with ~2hours worth. At 13GB/hr, that's only 26GB you'll need (actually, you'll need more for the renders and for the exported/converted output, so assume triple or ~75GB). If you wanted to keep it HD, you'll need to create an AVCHD or BD (or data disc) instead of a DVD-Video, so that will affect playing time also.
edit: you should KEEP your original tapes (so they could be re-worked later on), but if you have to remove the masters after exporting to disc, you should at least keep the NLE's EDL/Session Data and/or Authoring setups (those aren't very large anyway). -
Much of AVCHD is meant to be burned on DVD media, (since it has a different target than true BD) so that shouldn't set you back any. Just a matter of learning the Avchd/Bd structure (and encoding parameters) and getting the right apps for the job (tsmuxer, multiavchd, etc).
Help... want to store MiniDV to files
By dgorini in forum Video ConversionReplies: 7Last Post: 20th Dec 2009, 16:55 -
HELP! This is all new for me. Edit 2 separate minidv audio/video files.
By nexgraphics in forum Newbie / General discussionsReplies: 3Last Post: 17th Oct 2009, 09:45 -
Looking for new minidv camcorder. Panasonic miniDV or other?
By latin trident in forum Newbie / General discussionsReplies: 7Last Post: 22nd Oct 2008, 15:54 -
*.avi files captured from miniDV tapes with WinDV no longer plays
By gho in forum Software PlayingReplies: 5Last Post: 1st Jul 2008, 21:51 -
Make multiple video files from miniDV
By piwo4me in forum EditingReplies: 2Last Post: 27th May 2008, 16:53
